CFI 82 run engine without air pump?
Old Mar 12, 2022 | 12:25 AM
nitan2k's Avatar
nitan2k
Default CFI 82 run engine without air pump?
Hello all, 82 CFI owner. Made a thread here https://www.corvetteforum.com/forums...post1604855724 regarding coolant leak. I have removed the air compressor and air pump, and I wanna run the engine now to visually determine source of coolant leak. Can I run this engine at idle for like 5-10 max minutes with air pump off?
Old Mar 12, 2022 | 10:19 AM
BKbroiler's Avatar
BKbroiler
If the original air pump tubing and hoses are still there I believe there is a check valve which prevents exhaust coming out when the pump is disconnected. It wouldn't hurt to start the engine and see what happens.
Old Mar 12, 2022 | 01:48 PM
nitan2k's Avatar
nitan2k
Thanks. Should I still block the vac lines and hoses anyway, or leave em open?
Old Mar 12, 2022 | 02:32 PM
BKbroiler's Avatar
BKbroiler
I would seal them off at some point. If you can remove them from the manifolds and plug the openings that would be best.
Old Mar 14, 2022 | 08:19 PM
Fast81's Avatar
Fast81
MANY 82s are running around without them right now = no probs
To CFI 82 run engine without air pump?
