Looking At A 1981 - Need Some Advice Please?
Old Mar 22, 2022 | 07:45 PM
LMBlue's Avatar
LMBlue
Default Looking At A 1981 - Need Some Advice Please?
Folks
I am about to view a well cared for low mileage 1981 and have two questions please.
1) Is there anything specific on a 1981 issue wise that I should be looking for or should be aware of?
2) The car has had very little use (but is very well cared for) although it has stood for long periods, with maybe only a 1000 miles put on it in the last 10 years.
Can this cause issues anywhere and if so, what are the signs?
Thanks everyone.
Old Mar 22, 2022 | 08:24 PM
derekderek's Avatar
derekderek
they all sat for long periods of time. otherwise they would have 350k on them. belts, hoses, tires, brakes, T top seals... and that 81 has computer command controlled carb and ignition which is usually a PITA. usually replacing the carb and distributor with older style that don't require ecm inputs that never really worked well. none of this is deal breaker. if you can't deal with stuff like this get a C6. or an accord... frame and bird cage rust. body work and paint. those are the 2 biggest concerns.
Old Mar 22, 2022 | 08:57 PM
Hazmatr's Avatar
Hazmatr
It's 40 years plus, and been sitting. So you will have to replace the tires, cause they are probably at least 10 yrs old. I had a 79 which sat for awhile and needed to replace seat foam, carpet, carburettor rebuild, bulbs, vacuum hoses, and replace gaskets seals to stop leaks in engine, trans and dif. Expect this too: https://www.hobbycarcorvettes.net/cl...rking-options/
Old Mar 23, 2022 | 05:04 PM
71 Vert LS1's Avatar
71 Vert LS1
If possible bring jack stands and floor jack to get it up in the air so you can look underneath. Even better if it's driveable and insured rent an hour of shop time that has a lift.
If you have a local Corvette club contact them to see if they have some one that would help with the inspection. In lieu of that a well regarded body/mechanic person to help with the inspection.
Good luck.
Old Mar 23, 2022 | 05:55 PM
derekderek's Avatar
derekderek
roll down to post 107. read. especially rule 5. https://www.corvetteforum.com/forums...ispreloading=1
To Looking At A 1981 - Need Some Advice Please?
