69 Corvette Convertible Retirement Project
When the caster is set positive, the upper ball joint moves rearward about 1/4". That is the reason for the large shim stack on the rear stud, vs the front. I have heard factory cars can usually go up to around 2.75 with stock parts. GMs manual steer specs call for around 1. PS around 2.5
The rearward tilt on the balljoint axis means the R Fr spindle moves downward on a Right turn. The opposite effect on the left side. A left turn moves the spindle down. This has the effect f the driver trying to push the tire down when he turns, or actually lift the car slightly. So the overall effect looks like a "frown". The car's weight will force the wheel to the center, that is your self-centering effect.
So if you double the caster, say from 2 to 4, you will in effect be doubling the force required to turn the wheel. At speed you may really love it, and it may feel better. The trouble with MS is how much the effort drastically increases in a parking lot, while stopped, or moving at very low speeds. The increased effort is due to tire friction to ground. It is obviously very high when stopped. Drivers of MS cars know this very well and instinctively let the car move forward very slowly before they try to turn the wheel as it requires two strong arms if the car is perfectly still. So because tire contact patch friction is the primary force when slow, you may not feel very much difference by doubling caster. It would increase, but I would not expect it to double. However at speed that effort should double, and you may love the increased feel.
You 77 is manual steer, and IIRC you are running 2.5 castor. It would be relatively easy for you to experiment with it and see if you like, or not, the increased effort at speed, and at parking speed. No need to visit an alignment shop for a test. Just write down exactly how many shims you have now on your four studs, after your professional alignment, so that you can easily return to that. Do not change the TOTAL number of shims on the right side. Just take 1 shim out of the front and put it on the rear stud. You must make equal changes on both sides. When you run out of front shims that is all you can do. Then take it for a spin and see how the "effort" is. Doing it exactly this way will not change camber at all, only caster, and should not change toe-in significantly enough to worry about for a test drive or two. If you notice it gets "darty" all of a sudden off-center that means you dipped into toe-out. Just ignore that and concentrate on the effort required to turn the wheel.
I figured you would like the experimenting. And then you could find the "caster vs effort" balance that suits you and your driving style.
If you find you want to try more caster than what the above method will give you, that is when you need the offset shaft, or the slots, or both.
Example with numbers:
My factory 70 Z28 race car had a 10-15 in/lb steering wheel effort measured at the rim Factory PS gearbox and setting. One finger steering effort. Almost no tire feel at all. Horrible actually. An 86 IROC had the best highest effort fastest ratio recirculating gearbox ever to come out of GM and it was used in race cars for many years. Much better feel. Effort was 30-35 in-lb. I had my gearbox rebuilt by Tom Lee of CA to Nascar specs to 50-in-lb effort. I LOVED it after that. I also ran 6 degrees pos caster. Everyone that drove my car thought I had very good manual steering with terrific road feel, or a rack-n-pinion setup, but no one could believe it was PS. So maybe that is a good manual steering in-lb reading to shoot for. However my PS wheel effort was exactly the same at high speed or low speed. If I had to hazard a guess it would be that the PS assist did not even kick in until the car was at low speeds where the 11" wide slicks required considerable effort to turn. I drove a similar friends car with MS and could hardly get it to turn in the pit area at all, my arm muscles weren't big enough! LOL And mine still felt better on the track than his at higher speeds, so suspect I was running much more caster.
I use Librandi’s here in Harrisburg. Like Paul’s, not inexpensive, but you get what you pay for.
Regards,
Stan
Thanks to forum member Ken (C3Stroker) for selling me 5 of the 8......and I just found the remaining 3 I need on Ebay, making a full set. They ended up a little more $ than the reproductions, but for these parts, I felt it was worth it.
Have frame on dolly, preparing to weld up all the un-welded frame "skipped" areas, and install patch plate over front crossmember where the typical dents are. I am also replace one of the two lower A-arm mounts where a previous repair was poorly made. Checked rough alignments on the mounts, and everything so far looks very straight.
Gary Ramadei is preparing to build new trailing arm assemblies, with all my original cast parts, and the new stuff required.
And Jody Haas has finished the Autogear M23Z 4-speed transmission rebuild for the 77. And now he is starting to build the same transmission for this 69.
I will be making a road trip soon to pick up both the trailing arms and the transmissions.
Waiting for Mark Jones at VortecPro to have time to work on my 406 and the big block 468. .
<snip>
Those two a-arm mounts appear to be 16" from center to center, both front and back.
I see you already have a centerline marked, excellent!
One of mine was 3/8" off.
Measurements from 11 or 12 cars:
By the way....I love Zip, get most of my stuff from you guys. Your catalogs are the best and you always do the right thing on bad parts, etc. Thank you for that.
Some year I am going to come down to your Annual Corvette Show.
Jeff
Jeff
And......I will drive it alot....I promise you. I put 8000 miles on my 77 last year, as well as 5000 miles on my BLACK Harley. FYI......that bike has 137,000 miles on it, all by me.....the paint looks as good as the day I bought it in 2004.
