Stupid question
Old Apr 9, 2022 | 07:10 AM
Armybyrd21's Avatar
Armybyrd21
Default Stupid question
Can a cigarette lighter be used as a 12v source for a charger or does it not work that way since the cig charger has to be pushed in temporarily?
Old Apr 9, 2022 | 07:17 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Yes you can use the lighter receptacle as a 12v source - there are a multitude of adapters available for that purpose.
The ejection of the lighter element is built into the portion that pulls out. The lighter receptacle is always hot = 12v batt
Old Apr 9, 2022 | 07:47 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The biggest issue really is the size of the lighter receptacle. Seems more modern cars are a slightly different size. At least with the older C3's. Not really sure about the last of them and no idea of the year of your car.
Also keep in mind due to the wiring size. You will only be able to use a trickle charger through the lighter socket.
However, is it really difficult to just open the compartment door?
Old Apr 9, 2022 | 08:19 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I always have issues with my stock lighter. I added a double receptacle behind the dash and have 2 phone chargers tied into it. One for my Android and one for a CrApple. I ran it off a separate auxiliary fuse block tied into the fuse panel to trigger a relay giving it power on a 10 ga wire for direct battery supply.
Old Apr 9, 2022 | 09:34 AM
derekderek's Avatar
derekderek
it is no longer a cig lighter. no smoking allowed in C3's. it is a usb adapter port...
Old Apr 9, 2022 | 09:45 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
are cig lighters in shark cars fused? I know early GM cars are not.
Old Apr 9, 2022 | 10:00 AM
kodpkd's Avatar
kodpkd
I use my 68 lighter as a USB plug to my phone.
Old Apr 9, 2022 | 10:21 AM
bmotojoe's Avatar
bmotojoe
On a 77 a 20A fuse protects the CLK/LTR/CTSY circuit.
Old Apr 9, 2022 | 10:23 AM
interpon's Avatar
interpon
No clue what year op is..but 79 is 20 amp fused…no way are you going to out draw with a phone charger compared to heating an element.
should be no problem to use
With delay timer
Old Apr 9, 2022 | 10:38 AM
Nowhere Man
that’s good for latter owners. But early ones that are not should be careful leaving things plugged in over a long time.
Old Apr 9, 2022 | 02:20 PM
carriljc's Avatar
carriljc
Short answer: YES. Same as any other cig lighter.
To Stupid question
