Starter 1981 350
Just use the "S" terminal to land the purple wire...
Save your old starter solenoid if it's not cracked or broken.
Hard to find good solenoids nowadays...
Pictures are always good
https://www.corvetteforum.com/forums...tart-79-a.html
if you are tossing the old solenoid and looks like the picture and brown..don’t toss it..
You may need a assistant to press clutch pedal in and turn ignition switch to crank position when you are checking voltage at "S" terminal.
There are (2) Fusible Links at the starter solenoid.
Let's label them "A" & "B"
You say you have Headlights good, Fusible Link "B" is a direct path to your Headlight Switch. This tells me Fusible Link "B" is good.
You say when you turn ignition switch ON you can hear the heater fan running good, Fusible Link "A" is part of your charge circuit and also feeds your fuse panel. This tells me Fusible Link "A" is good.
Now, you have no gauges there is a Gauges fuse check that...
Your fan should NOT run in the START or crank position.
When you release the key from START back to the ON position and the fan starts again it is working correctly...
You have power to the "S" terminal with ALL conditions met.
I want you to try something...
Ignition switch off...
Remove the wire from the "S" terminal, screw the nut back on hand tight.
Makeup a short jumper 6" or so #10 or #12 gauge wire, #12 gauge wire minimum.
Ignition Switch still OFF
Clip one end on the "S" terminal post...
Now just touch the other end to the LARGE BATTERY post of the solenoid, does your starter solenoid engage starter?
If that's all good and you don't even get a click with the jumper wire I would take the starter back and have them test it.
Sounds like a pain but that's where your at...
What if the starter itself has a poor GRD? (missing mount bracket, missing GRD cable, starter to block surface greasy, etc)
Also;
I have seen on this forum a few "fudged-up" solenoid harnesses. Wrong wire eyelet terminal going to the wrong solenoid post with the wrong color wire and wrong gauge size.
Slight chance this is happening here.
