Fast idle adjustment
Old Apr 14, 2022 | 09:23 AM
grady white's Avatar
grady white
Default Fast idle adjustment
Hi all .. I rebuilt my 75 manual Q-Jet and it is running beautiful . I set the fast idle screw which is located behind the choke linkage to1600 at cold start per factory emission sticker . However reading Lars Book on carburetor rebuild in says set fast idle at 1200… any opinions thanks
Old Apr 14, 2022 | 09:59 AM
sw69vette's Avatar
sw69vette
Don`t go by the sticker , if Lars says 1200 , set at 1200
Steven
Old Apr 14, 2022 | 10:48 AM
lars's Avatar
lars
Not sure what info you're reading, but here are the facts:
  • I don't have a book about rebuilding carburetors.
  • I don't recommend 1200 for cold fast idle: this can be a hair low on some automatic cars when dropped into gear. I suggest 1250-1350 in neutral, with 1270 as a recommended good target number. All the carbs I build are set up and delivered with cold fast idle set to 1270.
  • You can set the cold fast idle to any rpm that produces a stable, reliable, and comfortable idle speed on your engine. I caution against excessively high fast idle speed since this produces unnecessary wear and tear on a cold automatic transmission when it is dropped into gear with high rpm and low fluid temperature. For this reason, I do not recommend the 1600 rpm cold fast idle spec.
Lars
To Fast idle adjustment
