Help with trim
Old Apr 16, 2022 | 10:53 AM
maxler's Avatar
maxler
Default Help with trim
Hi everyone. I need some help. Trying to get these to go on, does anyone have any ideas that would work? Where we try to push the molding on the clip just pushes off the fender.
Old Apr 16, 2022 | 11:05 AM
oldgto's Avatar
oldgto
The clip should have a little dimple on it.... the protrudes to the inside of the clip. That dimple is supposed to snap into a tiny hole that should be on the underside of the fender..... that holds the clip in place. I also had to hold the clip with a screwdriver or paint stick, etc. to help keep it seated in the hole while snapping the trim piece onto the clip. I hope I made that clear enough to understand?
Old Apr 16, 2022 | 11:59 AM
Mooser's Avatar
Mooser
See if there's anything useful in this thread
https://www.corvetteforum.com/forums...me-needed.html
(maybe post #7 or so)
M
Old Apr 17, 2022 | 07:56 AM
sleepchamber's Avatar
sleepchamber
My 72 has two clips on each side. Their placement dictates the position of the trim.
Old May 1, 2022 | 01:34 PM
maxler's Avatar
maxler
Thanks everyone. This helped a lot.
To Help with trim
