Stripped spark plug hole
Old Apr 20, 2022 | 08:06 AM
sonicss33's Avatar
sonicss33
http://castingrepair.locknstitch.com...thread-inserts
Look into these thread repair kits. They are the best out there. If not your choice, pull the head.
Old Apr 20, 2022 | 08:33 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by nitan2k
will do. Thanks. does it need to be exact tdc or close? asking because I don't know how to find TDC on the #3 cylinder, just #1.
Its the same principle....disconnect the dist. electric plug so the envine wont start. Remove the #3 plug and place your finger over the spark plug hole. Bump the starter u til pressure begins to blow your finger off the s.p. hole.Insert dial caliper tail into the s.p. hole and read the depth...remove the dial caliper...bump the starter a tiny amount.....take another reading with the dial caliper tail.
If the reading is getting smaller, the piston is approaching T.D.C. Remove the dial caliper and bump the engine again and take a reading. You want to get the smallest/shortest reading u til the reading stays the same after bumping the starter....the pizton has reaced the highest point.
Carefully measure the depth again with the dial caliper tail...this will be the approximate length fron the surface of the spark plud hole to the top of the piston (it doesnt matter if the piston is on the exhaust stroke as long as the piston has reached the top of its travel.
You will need a new spark plug about .030 SHORTER than the final reading you took with the dial caliper tail.
IF YOU ARE UNSURE about your accuracy in the final reading...allow a friend who is familar with dial calipers do the measuring for you so the piston top does not get damaved be ause the spark plug is too long.
Old Apr 20, 2022 | 09:28 AM
nitan2k's Avatar
nitan2k
i would pull the head as well. but OP is reluctant. he or prev owner may have been using a too-short plug when thread got hurt. it is a 462624 head. cheap and common. but these are not daily drivers. see what you need before buying parts. once one head comes off, replacing the pair must be considered. maybe ask bucaneer if any aftermarket or other replacement heads work well with crossfire. i know vortecs do not. the intake will not fit.
Yea prev owner, I never pulled plugs till now. My main concern with pulling the head is all the adjustments and crap involved with putting it back together. Feel like im gonna mess It up and a valve is gonna end up falling into or hitting the piston.
Old Apr 20, 2022 | 09:45 AM
kossuth's Avatar
kossuth
If these are OE iron heads I would view this as an opportunity to put the frontend of the car on a diet. I would also view it as an opportunity to perhaps increase the performance alittle. Make lemonade????
Old Apr 20, 2022 | 11:52 AM
REELAV8R's Avatar
REELAV8R
I fail to see how using a 3/4" reach plug in a 1/2" reach hole is going to accomplish anything. The plug uses all of the threads in the hole. Maybe one left unused? In any case if the threads are gone in the hole then that's it.
Maybe the threads are damaged on the plug and not the head? Try a new spark plug in that hole or at least a different one or different brand. It may be an easy fix. If it's still loose in the hole then it will need fixed. Personally on an old high mileage engine with original heads I'd try the heads on approach vs pulling the heads.
Old Apr 20, 2022 | 12:00 PM
nitan2k's Avatar
nitan2k
Threads aren't entirely gone, just when its approaches tightness, it loosens up again. No signs of stripping or anything unusual on the old plug. I have tried a new spark plug, I haven't tried the longer one yet tho.
Old Apr 20, 2022 | 02:50 PM
derekderek's Avatar
derekderek
tdc on #3. 18436572. 1-8-4 and 3 are 90 degrees apart. so when #1 is at tdc, #3 is halfway back up. so, turn crank 1/4 of a turn when you see tdc mark. are either valve cover off? when exhaust rocker is just closing and intake opening, cyl is at tdc. so when #3 or 2 have both valves moving, 3 and 2 are both at tdc. .
Old Apr 20, 2022 | 04:27 PM
Mr D.'s Avatar
Mr D.
Longer plug and JB Weld is your option at this point or pull the heads. There is no way a valve will fall into the engine or hit the piston by replacing the heads.
Old Apr 20, 2022 | 07:32 PM
derekderek's Avatar
derekderek
pull the head or heads. you tube videos and us. not rocket science. lots of these heads on fb marketplace.
Old Apr 20, 2022 | 07:33 PM
nitan2k's Avatar
nitan2k
I'll look into it more. Kinda hoped to avoid this. Also, longer plug didn't work
I wouldn't need to dissassemble the head itself right?
Old Apr 20, 2022 | 07:41 PM
HeadsU.P.'s Avatar
HeadsU.P.
Your biggest obstacle will be the removal of the stubborn, corroded, rusty, rounded corner exhaust manifold bolts.
Start soaking with PB Blaster now!
Old Apr 21, 2022 | 08:31 AM
derekderek's Avatar
derekderek
and a 14 mm 6 point socket. and if it slips, hammer a 12 point 13 mm on them. also, there is a taper at the bottom of most sockets. grind it off so the flats grab more of the bolt head and set the socket on with a hammer. i had a lot of practice with salt water corroded bolts on boat engines. you guys ain't seen nuthin!
