LED upgrade
Old May 1, 2022 | 01:14 AM
nitan2k's Avatar
nitan2k
Default LED upgrade
Hello, wanna upgrade my cornering (and eventually all) lights on my 1982 to LED's. I've already upgraded my gauge cluster and dash lights, it was simply a matter of buying the proper bulbs and plugging them in. My question is, do I need to add some relay or something with the LED on the cornering light, or can I just replace the bulb?
Old May 1, 2022 | 06:39 AM
Bikespace's Avatar
Bikespace
Yes, you will.
Instructions are in my writeup in Post 19, here:
https://www.corvetteforum.com/forums...s-learned.html
EDIT: The Cornering lights may be upgraded to LEDs directly. The Marker lights will need you to jump through hoops. My thread should explain it.
Old May 1, 2022 | 06:42 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I have a 77. it doesn't have cornering lights. Didn't really know any C3 did.
Just a question for your question.
What makes you think changing from incandescent bulbs to light emitting diodes is an upgrade?
I work on Harley's 6 days a week.
The failure rate of LED's is far and away higher than good old fashioned incandescent bulbs. And at 30 - 40 times the price.
Just wondering why anyone does this.
And yes I install LED's All the time. And yes I see them fail
Old May 1, 2022 | 06:47 AM
Bikespace's Avatar
Bikespace
Oh, it's an improvement. In a 40 y.o. car with few safety features, and a bunch of idiots watching their phones and not the road, I want to be seen. 80-82 C3s have cornering lights, but they just work with LEDs. It is the marker lights (which blink) that need a "Blinker Genie". These are technology borrowed from Harleys, appropriately enough.
Incandescent on the left (Passenger side) LED on the right (US Driver-side).
Old May 1, 2022 | 07:25 AM
4-vettes's Avatar
4-vettes
Drivers side is always left side. Always. Chevrolet never built a right hand drive C3. Although, there are a few converted ones over here. (Read, destroyed).
Right and left sides of a vehicle are always determined by sitting in or on Drivers seat. No exceptions.
Old May 1, 2022 | 01:34 PM
nitan2k's Avatar
nitan2k
Thank you @Bikespace . Im a little confused by your post though. I understand why the blinkers need the flasher module thing, but ur post says "Fortunately, the cornering lights do not interfere". So for just doing the cornering lights, I'll be fine with simply replacing the bulb?
Old May 1, 2022 | 01:37 PM
nitan2k's Avatar
nitan2k
Not sure why the LED's fail in your experience, maybe its an amp draw problem? I like how bright they are, they are absolutely gorgeous in my dash. I wanna try it out on the outside even if theres a chance of failure.
Old May 1, 2022 | 03:29 PM
Bikespace's Avatar
Bikespace
The cornering lights are on an independent circuit, and current only flows in one direction. In my 80, I could have upgraded these to LEDs without doing anything else. I didn't look at the wiring diagram for your 82, but it should be the same. So, yes, you should be able to upgrade to (white) LEDs for the cornering lights by simply replacing the bulbs.
Old May 1, 2022 | 03:46 PM
nitan2k's Avatar
nitan2k
thanks. I’ll verify with the wiring diagrams myself
Old May 1, 2022 | 03:59 PM
FosterV's Avatar
FosterV
You don't happen to have before and after of your dash lights do you/ Also what brand did you use? I considered this very thing after seeing the led section at the parts store yesterday, Sylvania I believe.
Old May 1, 2022 | 04:14 PM
nitan2k's Avatar
nitan2k
I dont have a full before picture, just the front dash. Here it is. This is how I got the car. Granted, some bulbs were probably dead, but regardless it was pretty dim. Also I didn't feel like yellow matched the silver green coloring of the car.
Here is a full after picture though. The color I bought was light blue, They are all the same bulb so I dont know why the instrument cluster is darker. I dont mind it though, In fact I think it actually looks better being darker. I was debating this color or green, but I think I like this better.
They're even visible in partial light, something that the incandescents definitely couldn't do.
Heres an amazon link to the bulbs. Several colors here so if you don't like mine you could probably get one more color correct to the original.
Amazon Amazon
Not sure if these bulbs will last as long as some of the very expensive ones I see at auto zone, but im about 4 months in with no problems.
Old May 1, 2022 | 04:17 PM
FosterV's Avatar
FosterV
damn that's a huge change. Thanks for that!
To LED upgrade
