Fuel pump line
Old May 3, 2022 | 08:53 AM
Golferdad's Avatar
Golferdad
Default Fuel pump line
I need to take my hard tube line off my fuel pump,so I can bend it to hook up to my Edelbrock carburetor,but,if I take that line off,will the gas keep running out,if so is there a way to stop it,while I rebend the line.
Old May 3, 2022 | 09:58 AM
Tampa Jerry's Avatar
Tampa Jerry
I have always jacked up the front of the car. I understand that you are only changing out the fuel line from the pump to the carb. It should not gush gas. That said, I clamp the rubber line with a pair of needle nose vice grips. I put rubber hoses on the vice grip ends to protect the fuel lines. Jerry
Old May 3, 2022 | 01:11 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
I use a hose clamping tool to flatten the rubber fuel line just in front of the pump
To Fuel pump line
