Trunk Tool-kit advice
Old May 12, 2022 | 08:59 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
A lot of good suggestions here but one thing I carry with me is a cheap Digital Meter....
Jebby
Old May 12, 2022 | 06:09 PM
Stallzer's Avatar
Stallzer
Old May 12, 2022 | 09:27 PM
Mark G's Avatar
Mark G
There are a lot of good suggestions here, but honestly, what the OP originally had plus a few cherry-picked items from this list should get you out of most binds you're likely to get into. Like someone said above, don't try to take too much. Best is, if you go with someone else ...on cruises, etc, spread things out a little and maybe they have wrenches and you have a socket set (etc). They have jumper cables, but you carry a few other tools, etc. The worst part about carrying a bunch of tools is they seem to eventually rattle and drive ya nuts.
Old May 12, 2022 | 11:08 PM
bluthundr's Avatar
bluthundr
This is what I keep in my car and it has come in handy a few times. I added an actual ratchet and a length of #12 wire to it and have used it several times to tighten a bolt, or adjust something, or pull apart a connector, or whatever goes wrong in older cars. No need to go crazy with a whole tool kit but you should carry a few things with you for a simple repair.
If you have HEI, put a spare module in there too, and this kit has all the tools you need to check to make sure you have power to the ignition and swap it out on the side of the road too.
Amazon Amazon
Old May 13, 2022 | 12:49 AM
Redbirdman's Avatar
Redbirdman
From: South of Phoenix Arizona, but North of no-where.
I agree with a couple things first. Jumpers are nice but the wrench to unbolt the battery is a must if you have the side mount terminals. But first is a tow strap and a couple S hooks. You have a good chance of someone towing you off the side of the hiway or from a traffic light if you break down rather than paying a couple hundred bucks for a flatbed. Over the years I replaced a boat trailer wheel bearing in a NAPA lot. Walked to a Walmart and brought a battery back to my dead pickup, and even run a Mack truck (with frozen diesel fuel) off a main hiway on the starter rather than have the troopers call BUBBA Towing. And of course, a fire extinguisher.
and don’t forget a couple bandaids.
Old May 13, 2022 | 10:51 PM
almightyloaf's Avatar
almightyloaf
3rd Gear
WOW! This is a much bigger response than I had expected!
A bunch of this stuff I hadn't thought of but makes tons of sense. Thanks for all the input!
Multiple people have asked for pictures, so here it is. It's in pretty rough aesthetic condition but the frame is good and it runs/drives well. It's a 1980 model for those who asked.
(sorry for the caption, this is the only interior photo I have right at the moment)
Old May 13, 2022 | 11:05 PM
Crimson Thunder's Avatar
Crimson Thunder
I also carry a spare long spark plug wire.
Old May 14, 2022 | 04:42 AM
Bikespace's Avatar
Bikespace
Awesome! 80s are the best, and you'll have a lot of fun with it.
Check the date codes on those tires before you drive to far. 7 years before replacement is the industry standard now.
Be safe, and enjoy your new car!
Old May 14, 2022 | 09:11 AM
almightyloaf
3rd Gear
Tires are the first item on the to-do list for sure. As soon as I have time this summer I'm getting a new set all around. Thinking about Cooper Cobras...
Old May 14, 2022 | 09:21 AM
Bikespace's Avatar
Bikespace
Those work on 80s. I may get Mickey Thompsons, if I ever get another set of 15" RWL tires at all. These are the stock option size of 255/60R15.
