Pace Car - Buying Advice
Old Jun 23, 2022 | 03:28 PM
Simonp3's Avatar
Simonp3
the G and C thing. there was a bad G they used. most of the hook was gone so it looked like a C. i thought it was 71 or 72, but it wouldn't surprise me a bit if they used a screwy stamp for years. looks like a very clean car. if you got leaks, you gotta wrench and swear and get oily. if you got frame or bird cage damage, you gotta learn how to mig weld and have a 3 car garage. frame in 1 bay. body in second bay. all the stuff you had to remove in the 3rd bay. i will take a leak or two any day. we love to scream IT IS A POS!!! RUN!!! none of us are saying that.
Amen. That's my priority, a "clean" birdcage and frame. mechanical defects any day. I have actually been a mechanic for 6 years, so that suits me well. I can't cope frame/birdcage rust. That is why i am choosing this one. The small things there are. is copeable. An evening with a steel brush, rust off, and some primer goes a long way.
And thanks, it sounds like i am making a good choice. Can't wait to pick it up on Thursday!
Old Jun 23, 2022 | 05:28 PM
derekderek's Avatar
derekderek
rust off? phosphoric acid treatment? euro version of naval jelly? and as much as we like to scream run away, we like it better when we can say "That car doesn't suck! Buy it or tell us where it is." cuz we get far less chances to look at a really good car. it is easy to find the rusty pieces of doodoo...
Old Jun 23, 2022 | 05:40 PM
Simonp3's Avatar
Simonp3
I guess it's like that, you remove the dirt, with a steel brush, use rust converter, and it dissolves the rust, and after 24 hours, you can paint over it. Never used it tough, sounds a bit too good to be true in my ears, but you never know, it is 2022 after all.
That sentence made my day, haha. I am 95% sure i am buying it. Need to see it with my own eyes. Is it really that good of an example? 😊
Old Jun 24, 2022 | 05:12 AM
hunt4cleanair's Avatar
hunt4cleanair
Love that photo! Anyone note there are no front spoilers installed?
Originally Posted by ralphspears
Old Jun 24, 2022 | 07:34 PM
RickM Z06's Avatar
RickM Z06
As a quick comparison this PC is for sale close to me. (If the link works) The car you are looking to buy appears to be much better condition.
File Type: html
Old Jun 25, 2022 | 02:41 AM
Simonp3's Avatar
Simonp3
Agreed, that needs some TLC :-)
Old Jun 26, 2022 | 10:18 AM
Dodosmike's Avatar
Dodosmike
Not that it matters, but is that paint on the trim tag?
Old Jun 26, 2022 | 10:23 AM
Simonp3's Avatar
Simonp3
I do not know
Old Jun 26, 2022 | 10:53 AM
mchar's Avatar
mchar
Also check the date on the tires - they may look very new but if they are old you won't want to drive on them very much.
Where in Denmark are you? And where in Norway id the car? I guess you will be taking a ferry with your trailer! Take pictures of the trip.
My wife is from Als.
Old Jun 26, 2022 | 10:57 AM
Simonp3's Avatar
Simonp3
Got a whole checklist, to i can remember it all. This is now added to it.
Small world! :-)
I am located in the middle of Jutland, in Skive. Taking the ferry from Hirtshals (2 Hour Drive) and the car is one hour from Kristiansand. So it almost couln't be easier :-) Cheaper than traveling to Sweden to pick one up.
Will take pictures. I am thinking about creating an Instagram profile for it.
Old Jun 26, 2022 | 12:01 PM
OldCarBum's Avatar
OldCarBum
Beautiful Pace Car.
Keep us posted!
Old Jun 26, 2022 | 03:35 PM
Dodosmike's Avatar
Dodosmike
Originally Posted by Simonp3
I do not know
Merely curious if it’s overspray from a repair.
paint looks fresh
how much if the stock exhaust is in place? (If that’s something your going to need for the plating process, ie emissions test)
before it’s fired up check the coolant overflow tank for any scum floating in the top. Possible contamination
use a screwdriver and poke at the rad cradle, rust can be covered up there with tick grease.
look between the a/c condenser and the radiation for leaves and signs of a leak. Black paint hides slot of sins.
Double check the tire date codes as somebody else mentioned.
seat belts retract correctly?
and recent drive shaft or u joint work?
brakes?
any play in the steering? Car off, steering unlocked, much movement in the wheel before tires move?
diff leaks?
can you remove the trim on top of the inside windshield? 3 screws (4?), looks for signs of rust UNDER the stainless t top trim.
looks like a nice car.
Old Jun 29, 2022 | 03:32 PM
  #33
Simonp3's Avatar
Simonp3
Gosh, im nervous about tomorrow!
Really hope the car is as the seller states!
Do you guys know the feeling?
Old Jun 29, 2022 | 06:46 PM
  #34
OldCarBum's Avatar
OldCarBum
I know the feeling.
Just wait until you find the car is just as nice as the seller is representing it and your insides start twisting as you mutter those words, “Would you take $$$”?
Old Jun 30, 2022 | 10:22 AM
  #35
Dodosmike's Avatar
Dodosmike
Found this pace car replica in Norway........
Seller wants 18.000 Dollars for it. With plate's on it in Denmark it's going to be around 21.000 Dollars. Only seen one for sale in my country, and i do not remember the price.
OP, you state its a PC replica. According to the VIN, its the real deal. See the "9"?
Just wanted to point that out.
