Back Spacing
Old Jun 27, 2022 | 01:36 PM
Redvette 66's Avatar
Redvette 66
5th Gear
Default Back Spacing
I purchased Gragar 61C rims for my 1979 corvette they are 15x8 5x4.75" Bolt Circle with 4.250 Back Spacing. When I went to the garage to have them installed; I just took on the rim to make sure it worked but it hit the brake caliber before it seats. What back spacing size should I go to?? Thanks Mike
Old Jun 27, 2022 | 02:59 PM
C3 Stroker's Avatar
C3 Stroker
You have the right size, and you have the right backspacing. You have just discovered why more Corvettes don't run Cragars.......the stock calipers are too large for them to seat. You must use 1/2" spacers with those rims to clear stock C3 calipers. The spacers are available from Cragar if you order them.
Old Jun 27, 2022 | 03:05 PM
Redvette 66
5th Gear
Thank you
Old Jun 27, 2022 | 03:18 PM
Redvette 66
5th Gear
Sir one other quetion, with the 1/2" spaces will I have to put new wheel studs in the hub assembly? Thanks
Old Jun 27, 2022 | 03:35 PM
C3 Stroker's Avatar
C3 Stroker
This kit will fit without having to change the wheel studs. It includes longer shank lug nuts to take up the space. You can get what you need here.........https://www.summitracing.com/parts/crr-29200
Old Jun 27, 2022 | 03:39 PM
Redvette 66
5th Gear
Thank you for your help
To Back Spacing
