Anchor Subwoofer in C3
Old Jul 14, 2022 | 10:10 AM
Vertigo1340's Avatar
Vertigo1340
5th Gear
Default Anchor Subwoofer in C3
Hey Everyone! I've been working on some small upgrades to the audio system in my 77 corvette. I recently picked up a powered subwoofer:
Kicker 11HS8 Kicker 11HS8
. My question is, what is the best way to anchor this in the rear storage compartment? The kit came with some 2" screws, but i'm concerned with using those on the fiberglass body. Any ideas would be helpful.
Cheers!
Old Jul 14, 2022 | 10:44 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Anchor it between the rear speakers but just make sure the screws aren't over an inch and an eighth long. Or something very careful when you drill the holes in the back panel. The gas tank is on the other side of that. And just drill a very small starter hole for the screws.
Old Jul 14, 2022 | 10:52 AM
Vertigo1340
5th Gear
Perfect! Thanks for the suggestion.
Old Jul 14, 2022 | 10:57 AM
ctmccloskey's Avatar
ctmccloskey
Welcome to the Corvette Forum Vertigo1340!
You are in the right place to get good solid information regarding your Corvette!
As far as the sub woofer a lot of people make a box that attaches to the rear wall of the area behind the seats. This is not very practical if you have a convertible unless the box is shallow and does not interfere with the top in its retracted position. I personally purchased a Box speaker setup that goes across the width of the entire rear section and still fits with the top down. The box houses a wide variety of speakers to give a good sound for something like a Jeep. It sounds great with a 40 watt amplifier attached to my Stereo even in a Convertible. Unfortunately this doesn't help the sound as the convertible top rests in front of the speakers blocking the sound. I have seen thinner boxes that work well but most have been custom built by creative Corvette owners. Being a Coupe would make it easier to have it mounted against the rear wall of the rear compartment and if you have to secure it you might be able to through bolt it to the rear wall as it is available forward of the fuel tank underneath the Car. I would probably consider some VELCRO and attach it securely in place or better yet strap it in position using battery type straps. You don't want it to break loose if you are involved in an accident and have it flying forward toward the passengers.
The best solution would likely be building a box and mounting all the speakers in it with your Sub in the middle. The box I have came with the speakers and a black carpet covering that looks okay in the Corvette. It was sold by Crutchfield a long time ago. As I mentioned it was primarily designed for the back of a CJ model jeep but fits in the rear of the C3 nicely. Being removable is handy as I take it out when I need the space for traveling in the C3. Being wide it is too big to come through the seats in case of an accident but I secure it by having the top in front of it blocking it from coming forward. If your car has T-Tops and secures them behind the seats then you might have issues with the amount of space between the tops and the rear wall.
To be honest with you having a big block and a convertible Corvette I am very limited to quality sounds systems that you can hear well enough at speeds. The boom box type speakers with an amplifier have made it possible but most audiophiles would not be happy with the quality of the sounds I get in my Convertible.
In our 1988 C4 it was much easier to install a good sound system after three of my Bose amplifiers stopped working. I used the boxes and mounted some good speakers but the rear glass used in the late C3's and the C4's makes the sounds bounce all over driving my ears nuts. I used the factory Bose wiring to power the system and now I have a modern stereo that has USB inputs on it and allows me to have hands free phone calls while driving.
Crutchfield has always been my go-to place for stereo questions, they might offer speaker housing solutions as well. The support you get from them makes it all worthwhile.
Old Jul 14, 2022 | 12:03 PM
Mark G's Avatar
Mark G
No ...I say go at it with a 6" long drill bit!! LOL. (just kidding, don't do that)
Nice find. Should really expand your audio. Give us a review how it sounds when yer done. How many speakers are in your car?
Old Jul 14, 2022 | 12:16 PM
Vertigo1340
5th Gear
Thanks for the warm welcome! Just got the car a few month back. I've been doing some small project on the car as it been mostly sitting for the past 10 years. The old radio and speakers wouldn't work at all, so i've replace the head unit with a RetroSound Long Beach radio and new 4x6 speakers in the dash. Eventually I want to add rear speakers and an amp, but that is a project for another weekend. I'll post some pictures when its done!
Old Jul 14, 2022 | 12:24 PM
Mark G's Avatar
Mark G
I like your thought process. Have to have good tunes!!
I haven't done this on my car, but something I 'plan' to do at some point when it gets out of the shop. That is to add speakers in the kick panels (lower door panels would be better, but I don't want to cut mine up), add small tweeters in the A-pillars. Of course a sub (somewhat like yours) ..and rear speakers. With an amp to provide enough power. All the vehicles I've been in or owned which had kick-a$$ stereo systems pretty much follow that scheme.
Old Jul 14, 2022 | 07:54 PM
grady white's Avatar
grady white
you would be absolutely crazy to drill holes in the compartment area 😬😬
Old Jul 14, 2022 | 07:58 PM
grady white
love the logic .. it needs mechanical work, but hey the sound system is much more important
Old Jul 14, 2022 | 08:31 PM
Vertigo1340
5th Gear
Any suggestions then?
Old Jul 14, 2022 | 09:16 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
I used some of these drywall anchors to mount a subwoofer like that to the back panel. I am not sure if I will keep it there because it causes a lot of vibrations in the back of the car. I might move it to the back of the passenger seat.
Old Jul 14, 2022 | 09:50 PM
ScreamingEagle70's Avatar
ScreamingEagle70
L HAVE a 70 with a kicker and a 1000 watt amp I put the sub face down because that's the kind I punched and the amp onto and used the roof top straps to keep it down and tight just like being in a concert
Old Jul 15, 2022 | 05:46 AM
CraigH's Avatar
CraigH
I used the storage box for mine.
Removed the jack and drilled out the retainer rivets.
Build a solid base with some well nuts in it so i could put bolts up from below to hold it in place.
Then attached sub to the board for a very solid and hidden setup.
Covered in detail here….. https://www.corvetteforum.com/forums...ourney-91.html
Old Jul 15, 2022 | 12:23 PM
Vertigo1340
5th Gear
I really like this setup. I don't think the sub I got will fit in the jack storage compartment, but i'll have to see if that is an option.
To Anchor Subwoofer in C3
