Door window install
Old Jul 19, 2022 | 11:58 PM
BBCorv70's Avatar
BBCorv70
Default Door window install
It’s been a long time since I last installed door glass. Can the outer felt strip and stainless trim be installed after the glass is installed?
Old Jul 20, 2022 | 12:31 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
I'm guessing the window down-stop would need lowering so the top of the glass would not block your ability to secure the strip(s).
By the way...do not nick or chip the edges of the glass while doing the installation-a few days later the glass may develop a big stress-crack...been there
Old Jul 20, 2022 | 06:42 AM
brileavi's Avatar
brileavi
I did mine with dropping the down window stops
Old Jul 20, 2022 | 08:05 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I've done Corvette and Camaro door glass weather seals. inner and outer by lowering the glass with the bottom stop without the need to completely remove the glass.
Biggest issue really is getting the outer strip's that fit correctly.
Best of luck.
Old Jul 20, 2022 | 09:36 PM
BBCorv70's Avatar
BBCorv70
Can the door glass be installed easily if the outer weatherstrip is already installed?
Old Jul 22, 2022 | 06:16 AM
4-vettes's Avatar
4-vettes
Yes
Old Jul 25, 2022 | 02:24 AM
BBCorv70's Avatar
BBCorv70
Yes, I replaced the outer seals many years ago, ran into problems with the strips being too long or placement of the tabs being off horizontally, the strip hit a stop at the rear of the door, causing the tabs to be too far forward to fit into the holes. I had to trim about 1/8" off the rear to get the tabs to line up with the holes while being butted up against the rear stop.
Many years later {last weekend), ran into the same issue.
Placement of the tabs wasn't perfect vertically either, tough getting all of them to snap in place and stay snapped.
Old Jul 25, 2022 | 02:29 AM
BBCorv70's Avatar
BBCorv70
Next question is can the door glass be installed with the roller fastened?
It would seem to be too thick to fit through the gap with the outer strips installed.
I heard of someone removing the roller before dropping the glass into the door, installed the roller after the glass was dropped into the door.
May not be an option with power windows, motor in the way?
Old Jul 25, 2022 | 04:28 AM
4-vettes's Avatar
4-vettes
Not certain on a Corvette with power windows. But I always install roller inside the door. Certainly there must be some point where the motor isn't in the way? Never had power windows in a C3 that I had to work on. my 77 has the old fashioned cranks. Worst case scenario is pull the bloody motor
Old Jul 25, 2022 | 09:41 AM
BBCorv70's Avatar
BBCorv70
I found a tech video from Corvette Central after posting this question. It appears the window can be inserted with the roller installed though it's a tight squeeze getting past the outer weather strip. This car has been under restoration for about three years now, doors were completely gutted by the shop which did most of the work. Now up to me to finish reassembly.
I don't want to mess with the motor unless I have to. Dangerous with no glass installed to counter the spring. I know I can lock the mechanism but this adds work.
To Door window install
