automatic shifter
Old Jul 24, 2022 | 06:42 PM
Yellow1980Vette's Avatar
Yellow1980Vette
Cruising
Default automatic shifter
I have an '80 Corvette with shifter issues.... it looks like the shifter control rod isn't completely engaging with the gear bracket. The tab (for lack of a better term) doesn't come up completely to push against the gear gate - I tried cleaning it out, but it still doesn't work completely properly - I have seen shifter rebuild kits but don't really want to rebuild the entire thing. Any ideas?
Old Jul 25, 2022 | 03:28 PM
Mooser's Avatar
Mooser
If it's even remotely like the earlier ones then there are two springs, one down inside the shaft near the bottom but another one up under the thumb button, if that one is missing the rod only comes part way up using the lower spring
M
Old Jul 26, 2022 | 08:17 PM
carriljc's Avatar
carriljc
Yellow1980Vette
If it's anything like a 1974 you wanna eyeball this thread. I used it to refurbish the 74 auto shifter that I got on Fleabay and it works wonderfully. https://www.corvetteforum.com/forums...mething-2.html
To automatic shifter
