Crazy Haps??
Old Aug 12, 2022 | 10:14 AM
JavaJolt78's Avatar
JavaJolt78
Default Crazy Haps??
1st off I usually don't drive my 78 in the rain but on the way home from a show I used the wipers and when I thought the rain was over I shut them off and they parked but the right one did a little up/down movement until I completely stopped and they both stayed parked???
Tried it again just to check and bingo same thing happened!!!
Any clues out there my panel of C3 gurus??
JJ78
Old Aug 12, 2022 | 04:54 PM
kanvasman's Avatar
kanvasman
Most likely something worn in the linkage between the 2 arms. That is where I would check . Maybe with them parked give 3ach one a wiggle and see what you find.
Old Aug 12, 2022 | 06:25 PM
JavaJolt78's Avatar
JavaJolt78
Tx kanvasman............ will do...
JJ78
Old Aug 12, 2022 | 08:06 PM
vettebuyer6369's Avatar
vettebuyer6369
What are “Haps?”
Old Aug 12, 2022 | 08:36 PM
loup68's Avatar
loup68
Army
I think that he means crazy happenings. Lou.
Old Aug 13, 2022 | 09:22 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Sounds like a park switch al0ng with the loose linkage.
Old Aug 13, 2022 | 09:27 AM
JavaJolt78's Avatar
JavaJolt78
Tx R R,
Can you tell me wtheck the park switch is B4 I start looking at the linkage?
JJ78
Old Aug 13, 2022 | 12:40 PM
Rescue Rogers
The parking switch is internal to the motor
Old Aug 13, 2022 | 12:42 PM
Rescue Rogers
Willcox used to sell them. I havent found a supplier. I will try and find a pic
Old Aug 13, 2022 | 12:44 PM
Rescue Rogers
Found one.....very surprised
https://www.ebay.com/itm/12531333624...71fe87d388f1ed
Old Aug 13, 2022 | 12:46 PM
JiminSTLouis's Avatar
JiminSTLouis
Originally Posted by vettebuyer6369
What are “Haps?”
Crazy Happenings.
Rescue Rogers
IF you go to willcoxs troubleshooting pages he has a benchtest that you can do in the car to test it
Old Aug 13, 2022 | 05:41 PM
bmotojoe's Avatar
bmotojoe
If you purchase a new park switch and you have the Standard Wiper Motor Without the pulse option the correct 2 speed switch part number is GM 4960755
You can find them on e-bay selling for between $20.00 - $25.00.
Don't settle for a premium price from a Corvette Vendor...
You can watch the Park Switch function if you want to skip ahead in a video I made to the 1:55 mark.
Old Aug 14, 2022 | 08:30 AM
JavaJolt78's Avatar
JavaJolt78
Did a static check on the wiper operation with key on acc..
All speeds worked and when I turned it off no up/down when they parked??
One thing I noticed is the the switch/stalk plunger with the knurled **** and white arrow on it did nothing when actuated in every position???
When moved down as for as the stalk would go it did do a one time sweep and parked!!!
JJ78
To Crazy Haps??
