Replaced engine value
Old Aug 21, 2022 | 07:13 AM
Arbruins's Avatar
Arbruins
4th Gear
Default Replaced engine value
Hello,
I am about to purchase a 1977 that originally came with a 350. It was replaced with a 454. Does the value of the car decrease because it is no longer stock?
Old Aug 21, 2022 | 07:17 AM
Mr D.'s Avatar
Mr D.
For a 1977 Vette I would say no, if this was a 1971 LT1 car than the answer would be yes.
Old Aug 21, 2022 | 07:50 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
might actually go up for this car with a big block in it
Old Aug 21, 2022 | 08:14 AM
1860army's Avatar
1860army
If you are the buyer then it decreases the value, The seller will say it increases the value, bottom line is the 77 is not all that collectable for some reason so it just doesn't matter. Did they change the front suspension, going to a big block usually requires different springs at least..
60
Old Aug 21, 2022 | 08:16 AM
midigike's Avatar
midigike
Yes and No answer here.
if it is a L88, ZR1, LT1 or a really nice original example that is NCRS worthy then yes it does.
Being that your Vette is a 70s model with the poor 160hp engine, a 454 in my opinion makes you’re car more fun and in turn more valuable.
Also, they made a ton of these late 70s models so there is plenty of inventory.
Old Aug 21, 2022 | 09:47 AM
Rescue Rogers
60
yes just stiffer springs and maybe a higher dampening rate on the shocks if they are a cheap KMart special. I have Bilsteins that worked great on both a small block and a big block
Old Aug 21, 2022 | 10:47 AM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
depends on what that 454 really is. most of them are RV and truck engines with no real power. sure, you can build them up, but it cost way more than a SB
Old Aug 21, 2022 | 01:51 PM
derekderek's Avatar
derekderek
iff you put a 4.3 in it you may devalue it a little. otherwise it is the car, not the engine you are shopping for and evaluating. and there is no less pricey way to 500 hp than a truck 454-preferably a gen 6 with aluminum roval heads and a ZZ502 or similar cam.
Old Aug 24, 2022 | 02:12 AM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
I just put a GM ZZ383 Stroker motor dressed up to look like an LT-1 motor. in my 72 L48. What a difference. New 2.5" SS exhuast, Dougs headers, McCloud clutch. QA1 front coil overs and all new suspension rubber bushings. Rebuilt trailing arms, Wilwood brakes. New tires. This on a 1 owner 72 Calif car without a speck of rust anywhere and has been garage kept and Guildstrand serviced all its life.I have receipts and all paperwork to prove it. Even have all the reg cards and orig BOS from the dealer. I say my car is worth more now then when I bought it.. Plus I kept all the original stuff to pass on if wanted.
Old Aug 24, 2022 | 02:21 AM
OldCarBum's Avatar
OldCarBum
If the engine was built properly and the swap was completed with quality parts and workmanship, then I would believe it would increase the value.
If the engine was poorly built and dumped in then I would say it decreases the value.
One thing to consider before purchasing this car is do you consider it increases or decreases the value?
Old Aug 24, 2022 | 03:40 AM
Arbruins's Avatar
Arbruins
4th Gear
I am told it’s from a station wagon. I took it for a ride and it has a lot of power.
Old Aug 24, 2022 | 04:06 AM
derekderek's Avatar
derekderek
post pics of the engine. try to get a pic of the flat pad right in front of the right cyl head. may have to angle camera around ac compressor to get it. they stopped using 454 in all passenger cars in 1974. it was truck only from 75 on up to 2002. even if it is the lowest compression truck motor with the smallest intake ports it is still a powerful engine. and Mass doesn't have emissions inspections so you most likely won't have any registration issues.
Old Aug 24, 2022 | 04:15 AM
Arbruins's Avatar
Arbruins
4th Gear
I will get pics soon then…I am told this was a Florida car up until the last 2 years or so. Last 25 years have been garage years. The interior is in good condition, better than most I have seen. Thank you for your posts.
Old Aug 24, 2022 | 11:26 AM
derekderek's Avatar
derekderek
and more than likely the seller wasn't following salt trucks up and down the mass pike in january and february the last couple years...
Old Aug 24, 2022 | 02:15 PM
OldCarBum's Avatar
OldCarBum
It doesn’t matter what vehicle it came out of unless it was something rare.
Even still, what matters most is how it was rebuilt what’s inside and how it runs now.
Old Aug 24, 2022 | 03:06 PM
derekderek's Avatar
derekderek
what matters most is how good the car is. engine smengine... running and driving is a good thing. but i will take a clean straight solid pretty car with a blown motor over a running driving rusty POS any day of the week.
Old Aug 25, 2022 | 12:05 AM
OldCarBum's Avatar
OldCarBum
You got that right!
To Replaced engine value
