Temperature Gauge Sending Unit
Old Aug 21, 2022 | 09:26 PM
RED-C5's Avatar
RED-C5
Default Temperature Gauge Sending Unit
I have a 69 350 and initially the temp gauge was maybe 120 fully hot. I grounded the gauge wire and it swung way past 250 almost pointing down. When I left it open (off the unit) it went under 100. A shop replaced the sending unit and said a "sender for a fan" had been installed. Now the gauge shows 230 to almost 250. Can this be corrected with a resistor? Or what would be the correct sender and source?
Old Aug 23, 2022 | 10:18 PM
grady white's Avatar
grady white
change ur thermostat see if that correct it
Old Aug 24, 2022 | 04:29 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Not certain a thermostat is the answer here.
First, get an I R temp sensor gun. Shoot the thermostat housing. What temp is it? If it agrees with your guage you have big issues.
If not, yes it can be corrected.
Old Aug 24, 2022 | 09:49 AM
RED-C5's Avatar
RED-C5
Yes I did that and it was about 190
To Temperature Gauge Sending Unit
