Vacuum Tank Leak
Old Aug 30, 2022 | 07:54 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
Default Vacuum Tank Leak
The vacuum tank for my '71 has a small crack in it that leaks when it's submerged in water and air is blown into the tank. It appears that some other cracks might be also be developing.
To seal them all up, can I use JB Weld or should I break out the MIG?
This novice thinks the tank is steel and not aluminum, can somebody verify this for me too? I don't want to try welding aluminum...
Thanks all,
Paul
Old Aug 30, 2022 | 07:58 PM
BBCorv70's Avatar
BBCorv70
Thanks all,
Paul
Pretty sure it's steel. Can you put a magnet to it?
Old Aug 30, 2022 | 08:45 PM
Mooser's Avatar
Mooser
Have a read through here
https://www.corvetteforum.com/forums...k-repairs.html
and / or here
https://www.corvetteforum.com/forums...nk-repair.html
M
Old Aug 31, 2022 | 01:45 PM
nwav8tor's Avatar
nwav8tor
Old Fart Pilot
DUH! Why didn't I think of that? Thanks
Originally Posted by Mooser
Thanks for those links Mooser! Gave me some other possibitities to consider...
To Vacuum Tank Leak
