On my ‘72 I noticed when I turn slowly I hear what sounds like the tires are rubbing though I know they aren’t. My first guess was maybe uv joints? It wouldn’t always do it taking off straight from a stop light but would when turning slowly every time. Any ideas on what I should be looking at? Sounds like it’s coming from the rear.
2016 C2 of Year
2015 C3 of Year Finalist
When was the rear end gear lube and posi fluid last changed? Change that out, use a 4 Oz bottle of GM posi lube, then do some figure 8's to work it into the clutches.
will do. I’m also reading about a snubber bushing that sounds like my symptoms.
just ordered a bottle of the GM additive. What rear end fluid should I use?
2016 C2 of Year
I have always used 80/90 weight gear lube and one bottle of the posi lube.. I have over 300,000 miles on my original 65 rear end with no issues.
Some use 85/140, some use 2 bottles posi lube.
Snubber bushing is a possibility but I would start with this. May solve your issue and just good proactive maintenance in any event.
