Stripping original paint on my '77. Trying the razor blade method and it seems to go pretty good. Couple questions; anybody know about how many blades I'll go through for an entire car? I've done about 3/4 of one of the t-tops and used 4 or 5 blades so far. Also, are some blades better than others, or do they all come out of the same factory in China? :-)
thanks in advance.
just buy a pack of 100 and don't count them. stripper combined with blades works better. i got good results with this scraper with regular sheet rock blades. https://www.lowes.com/pd/Marshalltow...per/5001900261 and do not scrape over the bonding strips on front and rear fenders. the glass rejects the blade good. blade stays between body and paint. but blade digs into the filler they used to fill the bonding strips. gouges it up pretty good. just sand there watching for color change as paint layers leave.
Thanks - I have one of those; I'll give it try. I was just wondering how many packs of 100 to order :-)
Might i add to wear some safety glasses, when i stripped mine the paint just flew everywhere.
I just used HF 100 pack of razor blades with an extra long handle and it went pretty quick.
Gouging is the main thing to try to avoid as best you can. If the old paint is coming off real well, you're lucky. A lot of guys will take it down to the GM black (if your car still has the GM black) ...and leave that as a base. But either way. Show us an after picture when you get it stripped..
My 71 had a crappy red paint over the original Ontario Orange. Took about 40 razor blades and took off both layers getting it down to the burnt red/brown original primer.
I found that newer sharper blades didn’t dig in. As they got dull, they would start to gouge. Lucky the factory primer was thick enough and I didn’t gouge too deep and I was able to block sand the primer off with no gouge marks.
Cheers,
Richard
When I did mine, I made a tool to hold the razor knife blade at about a 45 degree angle. Then I rounded the corners of the blade to prevent them from gouging. Just a few strokes on a whet stone occasionally and I doubt I went through 1/2 doz. The whole car was done within a week. I hate stripper!
Just got done stripping mine. Used probably 25 blades. Used my pneumatic sander with 80 grit to knock down the rest of the stubborn paint and smooth the body out.
I think a pack of 100 blades at Lowes was $8. Only used 4 80 grit discs.
Some cars ...like mine have umpteen paint jobs piled on top of each other! LOL. Then ya kind of have to use stripper. It's fast, I've done several cars. Had mine stripped and washed down to the GM black in a day...not even a full day (outside where fumes weren't bad).
But if razor blades work on yer paint, it's a definite opportunity. But when it doesn't work, I wouldn't hesitate to use stripper -- in accordance to good fiberglass-stripping practices.
