82 C3 Idling
Old Sep 21, 2022 | 07:45 PM
C3Flex's Avatar
C3Flex
Default 82 C3 Idling
Hello Everybody,
I hope all is well with the Corvette Forum community. I haven't been here in a while, though I am reaching out to you all for assistance today in diagnosing my idling issues. I just started my C3 for the first time in about a month and it is idling rough (see attached video). Does anyone have any advice on how to diagnose this issue? If so please feel free to share, any and all advice is welcome and appreciated.
File Type: mov
Old Sep 21, 2022 | 11:13 PM
Stormin_Normin's Avatar
Stormin_Normin
I would start by looking for a vacuum leak.
Old Sep 21, 2022 | 11:21 PM
C3Flex's Avatar
C3Flex
I'll start there, thanks. Though if my headlights operate normally is that enough troubleshooting to know if my vacuum lines are leaking?
Old Sep 22, 2022 | 12:53 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
My ex had a 84. Same setup, rough idle on hers I found one plug wire burnt through and a vacuum line popped off I think to the cruise control. But a small vacuum leak can really play with your EFI. Even if your headlights still operate.
Check all the normal tune up stuff first.
Fuel pressure is important on these crossfires as well.
You want to see 13 PSI at the throttle bodys.
12 is probably OK. These things will run funny if that pressure drops for any reason.
Old Oct 8, 2022 | 12:22 AM
C3Flex's Avatar
C3Flex
How do I check the fuel pressure?
To 82 C3 Idling
