Question about headlights
Old Sep 22, 2022 | 06:46 PM
cabman72's Avatar
cabman72
Default Question about headlights
On my 72: I can ride around all night with my low beams on and no problems. When I switch on the high beams, they work fine for a couple minutes and then they begin to flash on and off. All 4 headlights do this. I switch back to low beams and all is well. Is my dimmer switch bad or is it a wiring problem?
Old Sep 22, 2022 | 07:42 PM
210ken's Avatar
210ken
That’s not normal operation. Has any of the wiring been worked on or disturbed recently? Do your hazard flashers still work correctly?
Old Sep 22, 2022 | 07:48 PM
interpon's Avatar
interpon
Circuit breaker? Here is a thread..
https://www.corvetteforum.com/forums...t-breaker.html
Old Sep 22, 2022 | 08:44 PM
62corvette's Avatar
62corvette
Reproduction headlight switch. If so, they are famous for doing what you are experiencing.
Old Sep 22, 2022 | 09:17 PM
Greg's Avatar
Greg
Just another Corvette guy
Simple and permanent fix, add the headlight relays. I install them on all of my vintage cars. Corvette lights stop flashing and are much brighter. Also takes the load off of that older wiring. A very sensible and inexpensive upgrade.
CF member Street Rat also has a good thread on this subject:
https://www.corvetteforum.com/forums...-pictures.html
Cheers, Greg
Old Sep 22, 2022 | 09:53 PM
cabman72's Avatar
cabman72
Thanks for the responses. Makes sense that the aftermarket headlight switch can't handle all the amperage of 4 headlights. The relays seem like a good fix.
To Question about headlights
