3.07 vs 3.55
Old Sep 24, 2022 | 02:45 PM
Bone Shaker's Avatar
Bone Shaker
4th Gear
Default 3.07 vs 3.55
I love to cruse and thinking about changing rear differential from 3.07 to 3.55. I also have a 700r trans in my 1980 c3 already. I am looking for a few opinions to help me with this decision.
Old Sep 24, 2022 | 02:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
That will be a good fwy gear..
go to wallace racing calculators, enter in your parameters it will figure your cruise rpm at any speed.
Youll need your rear tire size
Old Sep 24, 2022 | 03:09 PM
69XR7's Avatar
69XR7
In my other car, I have a TKO-600 with a .68 overdrive, which is pretty close to the 700r .70 - I'm running a 3.50 gear and I've been very happy with it in town and on the highway. I would highly recommend going to the 3.55 gear or even 3.70 if you're not going to be on the expressway much.
Old Sep 24, 2022 | 03:59 PM
BKbroiler's Avatar
BKbroiler
It's simple arithmetic. 3.55 divided by 3.08 equals 1.15. So whatever rpm you're cruising at now, multiply by 1.15 for the new rpm, at the same car speed. In other words, rpm will increase by 15%.
Old Sep 24, 2022 | 05:17 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Do it!!!! it will be a lot more fun than you think. I went from 3.55 to 3.70 and loved it. Now I have a 4.11. Going from 3.07 to 3.55 will be a huge upgrade, its like adding 50 extra foot pounds of torque at low rpm, you might want to get a neck brace. With a 700r4 first gear of 3.06x3.55 you have a 10.86 final drive ratio...good drag racing gearing
Old Sep 24, 2022 | 05:25 PM
cv67's Avatar
cv67
St. Jude Donor '05
Good tip on that little math tidbit never heard that before
Old Sep 24, 2022 | 07:40 PM
60 SHARK's Avatar
60 SHARK
I love my TKO 500 with the 3:70 I have. It’s quick off the line , then perfect at 75mph cruzeing. Fun at both ends,
Old Sep 24, 2022 | 08:41 PM
How Are You's Avatar
How Are You
Old Sep 24, 2022 | 10:33 PM
Bone Shaker
4th Gear
What about fuel consumption and engine wear
Old Sep 25, 2022 | 01:07 AM
OMF's Avatar
OMF
We don't drive corvettes for fuel mileage.....
Old Sep 25, 2022 | 06:23 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
And engine wear? I've been spinning mine well over 3,000 RPM for hours on end for the last 30 couple years. Yes I freshened it up about 5 years ago. but still at Std bore. original crank and rods. It's a 350 Chev. good oil and proper maintenance and considering the miles per year most of these get driven.
Just not a real concern.
Old Sep 25, 2022 | 07:04 AM
Rescue Rogers
700r4 has overdrive.....if you are worried about gas mileage and rpm you bought the wrong car
Old Sep 26, 2022 | 02:57 PM
Richard Daugird's Avatar
Richard Daugird
4:11! As soon as I get OD I'm making the switch from my 3:55s.
Old Sep 26, 2022 | 04:21 PM
REELAV8R's Avatar
REELAV8R
Only so much the tires can do to keep from spinning. Unless you run some kind of drag radial you’ll just burn more rubber above 3.55 from a start. Unless your looking for the acceleration after launch, then by all means 3.73, 4.11 whatever.
The 3.55 is a good all around ratio with street tires. Or at least is has been for me. I still have can’t hook up at launch with my th350 and 3.55. Shift to second at full acceleration breaks loose as well. So with the 7004r lower 1st gear, lots of wheel spin.
To 3.07 vs 3.55
