Manual vs Automatic Transmission
Old Sep 30, 2022 | 02:58 PM
1978Ray's Avatar
1978Ray
1st Gear
Default Manual vs Automatic Transmission
Hello Everyone!
I have a 1978 C3 with a 4 speed manual transmission that I want to change over to an automatic transmission…mainly because I’ll feel more comfortable driving it that way. Does anyone have any insight on possible complications that may arise from this?
Thank you in advance!
Chrissy
Popular Reply
Sep 30, 2022, 03:33 PM
Greg's Avatar
Greg
Just another Corvette guy
Hey Chrissy,
Being as less than 18% of 1978 Corvettes came with a 4 speed, this would make your car pretty desirable among those seeking a '78. There are literally thousands of '78's with automatic transmissions. So why don't you consider selling your (rarer) car and buying one that already has the equipment installed that you desire? You'll probably come out $$$ ahead in the end.
Cheers, Greg
Old Sep 30, 2022 | 03:33 PM
Greg's Avatar
Greg
Hey Chrissy,
Cheers, Greg
Old Sep 30, 2022 | 04:46 PM
Gordonm's Avatar
Gordonm
To get the auto in there you are going to have to cut the crossmember. $ speed cars had a fixed crossmember due to the size of the trans. It can be removed and installed with the fixed cross member. The automatic cars had a removable crossmember because te trans is bigger. You can’t get an automatic tartans in a 4 speed frame unless the cross member is cut or you have the body off. Plus the 4 speed cars as said above are more desirable.
Old Sep 30, 2022 | 04:48 PM
ChiliPepperGarage's Avatar
ChiliPepperGarage
I have a solution. I'll trade you my '79 automatic car for your stick shift car!
(Yes, it has an '80-'82 nose and rear)
Old Sep 30, 2022 | 04:49 PM
Greg's Avatar
Greg
BINGO!
Old Sep 30, 2022 | 05:29 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Bottom line. Yes it can be done. Yes it will be expensive. 4 Speed cars are worth on average 2K more than a simular Auto car. So...... You will spend a TON of money to devalue your car.
Sell it and buy the cheaper Automatic car!
Old Sep 30, 2022 | 06:35 PM
Richard Daugird's Avatar
Richard Daugird
One more vote for sell or trade it for an automatic.
Old Sep 30, 2022 | 06:52 PM
BLUE1972's Avatar
BLUE1972
Silver Sport makes a kit = will let you see the cost.
I would keep the 4 speed
Old Sep 30, 2022 | 09:02 PM
Richard Daugird
Might be tough for a girl to drive if it has a stiff clutch.
Old Sep 30, 2022 | 09:13 PM
mikeb's Avatar
mikeb
2023 Corvette of the Year Finalist - Unmodified
2022 C3 of the Year Winner - Unmodified
Old Sep 30, 2022 | 09:21 PM
ChiliPepperGarage
I thought girls liked a stiff.........never mind.
Old Sep 30, 2022 | 09:26 PM
Dirty Dalton's Avatar
Dirty Dalton
My Daughter has driven mine, no sweat.
And there is the cognisanti (sp?) thing I posted a week or two ago.
Old Sep 30, 2022 | 10:29 PM
Richard Daugird
Manual transmission is not for everyone. Maybe she's young and in-experienced. Maybe she inherited the car. Crissy, I suggest you practice somewhere where there is not much traffic, you may find it's a lot of fun driving a manual trans car.
Old Sep 30, 2022 | 11:05 PM
4-vettes's Avatar
4-vettes
Agreed, practice and learn to DRIVE. you will find driving a car is much, much more fun than simply riding in one.
There is a reason the manual cars command thousands more than Automatic cars.
REAL CARS DON'T SHIFT THEMSELVES!
Old Oct 1, 2022 | 07:24 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
You have to buy
  1. a transmission
  2. A corvette shifter
  3. The correct shifter trim plate
  4. If its a newer transmission with overdrive you might have to do some tunnel work
  5. The down shift cable for the carburetor for passing gear
  6. A carb that has the provision for the cable
  7. Run cooling lines
  8. Add a transmission cooler in front of the radiator
  9. And make your crossmember removable.
  10. remove clutch pedal
If you go to some of the transmission sights or corvette parts ripoff places they may have most parts in kit form to make it easier
Old Oct 1, 2022 | 07:44 AM
Rescue Rogers
the automatic section of this talks about the differnt transmissions of the time, there are better ones now available. I havent seen an 4 speed to auto kit
https://www.chevydiy.com/c3-corvette...nd-drivelines/
Old Oct 1, 2022 | 12:33 PM
Mark G's Avatar
Mark G
And if you were to sell & buy an 'automatic' vette, you could consider going to an 82 which has OD and fuel injection too.
How much have you driven it around? Maybe the issue is familiarity ...need more time behind the wheel. Most people prefer the manual. Maybe given more time to get familiar with the shifting you will too (??).
To Manual vs Automatic Transmission
Old Oct 1, 2022 | 12:52 PM
How Are You's Avatar
How Are You
My Vette seems pretty real to me and I never miss a shift!
Old Oct 1, 2022 | 01:36 PM
carriljc's Avatar
carriljc
1978Ray
Actually quite easy. I swapped my Richmond 6 speed to a 200-4R this year. Hardest part would be modifying the crossmember (I think the 78 Manual crossmember was welded in). I had already cut mine to put in the 6 Speed..
I actually left my clutch pedal installed in case I want to swap back for fun, or I break the automatic. I really like my new automatic.
There are a couple of threads on this forum. Do a search and you'll find them. If you cannot find them say so and I'll link them.
Other than the crossmember you can buy just about everything to bolt one in....only some minor fabrication and tweaking.
Old Oct 2, 2022 | 05:26 AM
4-vettes's Avatar
4-vettes
It may seem real to you. But riding around in an Automatic is nothing like driving a car.
It's not real to me. And I'm not alone. Manuals command a higher price because they are favored over the girls car.
