Borgeson Steering
Old Oct 15, 2022 | 10:38 PM
bobby70's Avatar
bobby70
Default Borgeson Steering
HI-ALL I'm thinking to install the Borgeson steering box and saw a lot of threads. about it but some People buys the power steering so I took mine off and its on the bench .can I test it on the bench to see how good it is because it will save me a lot of money if I. don't need to buy one thanks for the help bob
Old Oct 15, 2022 | 10:53 PM
69L88's Avatar
69L88
What specifically did you remove and why?
Old Oct 15, 2022 | 11:15 PM
bobby70's Avatar
bobby70
I. took out power steering pump to paint and to check. if it was working. correct and I. had to. put in a new water pump and maybe a Borgeson steering box
Old Oct 15, 2022 | 11:23 PM
How Are You's Avatar
How Are You
What?
Old Oct 16, 2022 | 12:11 AM
Mark G's Avatar
Mark G
I think the OP is asking if he can test his power steering if he has it on the bench.
OP, most likely your steering box is 'loose' and also the flexible coupler (picture below) is also loose. This is real common on C3's. You can remove it, put on the bench and 'feel' it for wear. If you rebuild your original steering box (steering gear) and replace the flexible coupler, your steering should be nice and tight (assuming ball joints and steering joints are in good condition). That is the cheapest way to have tighter steering. There are instruction on the internet, or the factory Corvette service manual. There are some people on this site who rebuild them also. Or you can install a borgeson, but that is going to cost you more and involve a lot more work.
Flexible coupler:
https://www.ebay.com/itm/115185651184
Old Oct 16, 2022 | 03:29 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
I'm thinking he wants to bench test his power steering pump.
without special equipment to measure flow and pressure. At a specific RPM. Not certain how one would do this at home.
But then, Not certain why he wants to put jeep steering in his Corvette, but lots of people do it.
Old Oct 16, 2022 | 06:06 PM
Mark G's Avatar
Mark G
Before Borgeson, that was a retrofit some people did to get Saginaw-style power steering and ditch the ram/hoses. Maybe he's got one laying around....?? Borgeson pretty much improved the idea in a kit form.
Old Oct 16, 2022 | 09:14 PM
bobby70's Avatar
bobby70
Who said anything about jeep Steering ?
Old Oct 16, 2022 | 10:10 PM
4-vettes's Avatar
4-vettes
What do you think the Borgeson kit is?
Old Oct 16, 2022 | 11:16 PM
Bikespace's Avatar
Bikespace
Post a photo! You can also try to sell the cores in the for sale section.
When I converted my 79 to Borgeson, the only part I did not replace was the power steering pump. It failed within a few weeks.
To Borgeson Steering
