C3 Gauges and Tachometer, HELP!
Old Oct 18, 2022 | 09:47 PM
GrittyFilms's Avatar
GrittyFilms
8th Gear
Default C3 Gauges and Tachometer, HELP!
Hi Folks,
I bought a 1978 Silver Anniversary with only 12k miles a couple months ago. Everything except for the Tachometer worked when I got it, including the clock! I had a vintage radio installed with bluetooth and XM. The radio installer broke my clock. Good news they paid for a new one. I opened up the center console replaced all of the non-workig lights and the paper circuitboard. I also replaced the circuit board on the Tach. That didn't work -- I plugged the tach wire directly to the distributer and that worked. Drove around with a working tach for 3 weeks. When I installed the clock and was re-installing the gauge cluster I noticed that all of the working gauges are not working now, including the tach! Only thing that works now is the clock! What did I do wrong? Should I have disconnected the battery before re-installing the gauge cluster? Did I burn out the two new circuit boards? Did I blow a fuse? This really sucks. Back to square one. I thought I was doing a great job. I'm not a mechanic or an electrician.
Can someone help me? Tell me what I did wrong? Thank you!
Best,
Ted
Old Oct 18, 2022 | 10:00 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
Check the gauge fuse. The clock is directly wired.
__________________
Greg
Old Oct 18, 2022 | 10:01 PM
Tech141's Avatar
Tech141
When you say your gauges don't work, what do you mean? Are they showing ANYTHING/any deflection? Is there any difference between key on and key off?
When you pulled the cluster, could you have possibly disconnected the Ground wire? Ground is very important, as it completes the circuit.
It sounds, to me, that you disconnected the Ground wire.
Old Oct 18, 2022 | 10:05 PM
GrittyFilms
8th Gear
I may have disconnected the ground wire. I'm getting nothing from the gauges. Clock continues to run. And why does my Tach not work now, too? How can I find the ground wire? I only have connected the big wiring harness to the center of the cluster. Thats what I connect and disconnect.
GrittyFilms
8th Gear
Okay. I can try that.
Old Oct 18, 2022 | 10:08 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Or simply blew a fuse because something touched that shouldn't have. Always disconnect the battery when working on anything electrical.
Old Oct 18, 2022 | 10:12 PM
GrittyFilms
8th Gear
Since I'm new to this I'm not going to beat myself up over mistakes, but I had a hunch that I should've done that. Should trust my gut. Thanks. Hopefully If I replace the fuse the guage cluster and the tachometer will work again. Ugh. Didn't know they were connected but maybe they run off the same fuse?
Old Oct 19, 2022 | 11:46 PM
GrittyFilms
8th Gear
UPDATE. I replaced the fuse and all of the gauges work, including the Tach. I didn't think the gauge fuse was for the Tach, too. Crazy!
To C3 Gauges and Tachometer, HELP!
