Extend battery cable.
Old Nov 24, 2022 | 07:39 PM
540 vette's Avatar
540 vette
Default Extend battery cable.
I need yo extend my positive battery cable. Best way to do it. I am not replacing the whole length.
Old Nov 24, 2022 | 07:55 PM
Mooser's Avatar
Mooser
How much do you need (and why? screwed up end??)
M
Old Nov 24, 2022 | 08:03 PM
Mooser's Avatar
Mooser
Boat guys have neat stuff
HYDRA® Battery Cable Extender Kit, can accommodate up to 2-gauge wire connecting back to the posts on the battery terminal.
Uses stainless steel hardware with a 5/16-18 stud and a case to protect the in-line connection.
M
Old Nov 24, 2022 | 10:49 PM
carriljc's Avatar
carriljc
540 vette
Assuming you need the battery end......I used one of these years ago (5? 10?) and it is still in use ... easy peasy lemon squeezy .... doesn't rust, bust, or collect dust....works fine, lasts a long time, drains to the bilge.... but anyway.....
You can get either the side terminal type or the top terminal type. About 9" long as mentioned in link.
https://www.walmart.com/ip/Everstart...Saver/29029227
https://www.walmart.com/ip/EverStart...ll&athena=true
Old Nov 24, 2022 | 11:59 PM
CarterDawson's Avatar
CarterDawson
Asumming your terminal bolt is stripped out this is what I did. Not my video, but it’s where I got the idea.
https://m.youtube.com/watch?v=Bsw0rr...ist=WL&index=1
Old Nov 25, 2022 | 02:30 AM
540 vette's Avatar
540 vette
M
About 6-10 inches. They put the wrong battery in the car and it is facing the wrong way and they cut down the cable to fit it.
Old Nov 25, 2022 | 07:35 AM
Mooser's Avatar
Mooser
Nice
They make these things
Where that one end is a female connector for a side post end. then you could adapt or cut the top-post end off and install a side-post end. Not ideal but ???
I know there are 2g butt crimp connectors available that would more or less do what that thing I posted above does also
M
Old Nov 25, 2022 | 07:42 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I'd be livid if a shop did that hack before asking me first. Take it back to the shop and tell them to do it right at their expense.
Old Nov 25, 2022 | 04:02 PM
righthanddrive's Avatar
righthanddrive
Does anybody know what gauge wire the 1978 uses.?
I am installing an LT1 into it and had to move the engine forward to clear my hydraulic clutch. I figured I may as well replace the cable and make it 'RED' at the same time.
Old Nov 25, 2022 | 05:40 PM
540 vette's Avatar
540 vette
I don't take my car to shops. I do all my own work. Second it was like that when I bought it.
Old Nov 26, 2022 | 01:11 PM
How Are You's Avatar
How Are You
These guys have everything you need for a professional install at reasonable prices.
https://www.batterycablesusa.com/
Old Nov 27, 2022 | 02:39 AM
TCracingCA's Avatar
TCracingCA
Use this opportunity to wire in a higher end kill switch. PS keep ground as short as possible, and for the hot ensure it doesn't rub on things!
Old Nov 27, 2022 | 01:56 PM
540 vette's Avatar
540 vette
I was thinking about doing that.
To Extend battery cable.
