Corvette C3 Opinion
Old Dec 9, 2022 | 03:19 AM
Iacopo's Avatar
Iacopo
fantastic thanks.
Old Dec 9, 2022 | 03:27 AM
Iacopo's Avatar
Iacopo
this are the rims of the car:
Do you think are after 1979?
In case what do you suggest me for fixing?
1) trasform the rim (if it's possible) into the one with black center
2) put the black cap?
3) put the silver cap?
4) other solution
thank you
Old Dec 9, 2022 | 12:48 PM
interpon's Avatar
interpon
Black center cap…black in center of wheel..and bare cast aluminum in wheel slots..not black..
I polished these but original were clearcoated and have machine lines..
Old Dec 10, 2022 | 02:19 AM
Iacopo's Avatar
Iacopo
So, for fixing the center, can i just paint the wheel center of black?
thank you
Old Dec 10, 2022 | 06:14 AM
Stephen Irons's Avatar
Stephen Irons
2024 C3 of the Year Finalist - Unmodified
thank you
Hi
I have aftermarket wheels on my '78. They are the later type (1980 onwards), polished wheels, with black painted slots, but no black in the centre. The Centre Caps are the black type. I actually think they look good, even though I know they are not correct for '78.
I think if you try to paint the centre of the wheel black, it may not look good as it may be hard to get the paint to adhere to the polished rim. If it were me, I'd just put the black centre caps on. Incidentally, I have fixed the centre caps on my wheels with some duct tape on the inside, the are expensive and I don't want to loose one of get it stolen!
With care you should be able to paint the bumperettes in a satin black finish, which will look better than the body colour.
I assume you have bought the car?
Where in Italy are you?
Here's what my wheels look like:
Oh, and I sent you a PM!
Old Dec 10, 2022 | 06:37 AM
C3 4ME's Avatar
C3 4ME
Yes, you can just paint the center black if you choose. I did exactly that on my 79. As far as the video, as someone stated above, it really doesn't show much. Any areas of concern were not shown. The engine is not seen, nor is the underside of the car. I too would want to know why it was repainted. Also, there are some strange what looks like covered holes in front of the tail light lenses. I'm not sure what's going on there, but it's definitely not stock. If you're able, please post more detailed pictures and then we can give more detailed feedback. Good luck!
Old Dec 10, 2022 | 09:06 AM
Bikespace's Avatar
Bikespace
Did you go take a look at the car? Did you buy it?
Those are likely reproduction wheels. Nothing wrong with them. You can buy new sets of YJ8 (black center, up to 1979) or N90 (silver center), and whatever center caps you want. Or paint those. Those look REALLY shiny, like they are the chrome repros in the link below.
Shipping and import may cost a bunch, but at $1000- for a brand new set, it's not worth sweating over.
https://www.zip-corvette.com/68-82-c...heels-set.html
Old Dec 10, 2022 | 08:18 PM
Kerschmolar's Avatar
Kerschmolar
Here’s an original wheel with the factory texture. This is a 235/6015(26” dia) tire vs original 255/60/15(27”dia). IMO the 255’s fit the wheel well better. Unfortunately these wheels were bent and replaced with18x8, 255/45/18. These new 18” wheels/tires made a major improvement in tracking and cornering.
Charlie
Old Dec 11, 2022 | 01:33 AM
Iacopo's Avatar
Iacopo
Seems that rims have been chromed, you can see some chrome "peeling off".
Here are some photos of the car:
Old Dec 11, 2022 | 10:47 AM
Stephen Irons
So, have you bought it??
Old Dec 11, 2022 | 11:13 AM
interpon's Avatar
interpon
Thanks for pics..more is always better..especially pronerustareas..
to me it looks like an honest original car but needs works..this only based n sme pics..
- bushings all around and probably other typical worn items.
- spray bomb all under
no clue what open hose is in pic or why there is a number etched..
if you want to see a 79 new..go here..i often reference this..
https://forums.corvetteactioncenter....ic-white.9529/
Old Dec 11, 2022 | 11:33 AM
Stephen Irons
My guess is that the number etched into the chassis is the VIN, although there seem to be a few too many numbers on the end! But having the VIN stamp3d into the chassis is certainly a requirement here in France (unless the car is actually registered as a "collection vehicle".
The open hose looks a little like the fuel line! So I'd have to assume that it has a different fuel pump system on it? I see it has an electric radiator fan and an altered fan shroud, so maybe a previous owner thought they were some sort of hod-rodder!😄
And yes, they were let loose with a rattle can of black underneath.😄
Old Dec 11, 2022 | 11:56 AM
  #33
interpon's Avatar
interpon
good info
my guess is fan is factory electric on a 79.
File Type: mov
Old Dec 11, 2022 | 12:02 PM
  #34
Iacopo's Avatar
Iacopo
yes
Old Dec 11, 2022 | 12:04 PM
  #35
Iacopo's Avatar
Iacopo
What do you mean for "- spray bomb all under" ?
Old Dec 11, 2022 | 12:32 PM
  #36
interpon's Avatar
interpon
black spray paint all over under the car..see the pic i posted and link you can see there is no underbody paint after assembly..
it may or may not hide anything..
also curious about that open end in pic as mentioned
Old Dec 11, 2022 | 12:38 PM
  #37
interpon's Avatar
interpon
Congrats on your car…it will be exciting to learn with you about your car!
post many pics as this forum in many cases enjoy your journey and advise.
I was in your same position 3.5 years ago.this forum is the best..
To Corvette C3 Opinion
Old Dec 11, 2022 | 12:42 PM
  #38
Iacopo's Avatar
Iacopo
this forum and you guys a great!
Yes, i start right now my journey!!
Old Dec 11, 2022 | 03:32 PM
  #39
Stephen Irons
Congratulations! Welcome to the Corvette community!
(Don't forget to check your private messages!&#128521
Old Jul 15, 2023 | 05:18 PM
  #40
RubyRedMetallic's Avatar
RubyRedMetallic
To me it looks like it's been left on jack stands without supporting the front. The side view looks like the car has the common bend from jacking up wrong. Gap on doors is only big at the top. Looks bent to me
