Dead again
Old Dec 6, 2022 | 09:20 PM
bobby70's Avatar
bobby70
Default Dead again
HI everyone. I just can't get a break. my 70 all. done that what I thought next day the new battery was DEAD come on give me a break so I charged it took it out for a ride took it too my speed shop and hard the timing check its ok started right up took it home and it was charging so put it. to bed .next day DEAD.so started poking around with the fuse block. and with car off I had power to all the fuse on the left side which one was for the brake light so car off key out I step on the brake pedal and the lights came on.something is live all the time and drawing the battery DEAD any body have any clue where to check ,I think this is going to be HARD Thanks for your help bob
Old Dec 6, 2022 | 10:31 PM
Mooser's Avatar
Mooser
Clock, lighter, courtesy lights,
Tail lights
Stop and hazard lights
Instrument lights
Are all powered without the key on
The other side of the fuse block is switched with the key
Heater
Wipers
Radio
Signals / backup
Gauges
Pull the clock fuse and nothing else should be "running" with the key off
Start there, if you have a good ammeter you can check each fuse (pull the fuse and check over where it was plugged in) and see if you can tell what circuit it's on.
There are a few other circuits that don't go through the block, alarm etc but start where it's easy to check
M
Old Dec 6, 2022 | 11:21 PM
Bikespace's Avatar
Bikespace
If there is a bad diode in the alternator, that could be the problem, too. This seems to be a common failure mode on the Forum, and is not fused either (well, not in a way that is easy to test).
Old Dec 6, 2022 | 11:33 PM
kansas123's Avatar
kansas123
And the diode is very easy to replace too.
Old Dec 6, 2022 | 11:56 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
to ease the pain you need an ammeter to
show the drain.
a test light may give a hint.
basically hook meter/ light between pos bat post and disconnected pos cable.
the meter/light makes the connection.
note amp draw/light brightness,
make sure door lights are off and hood light off, key off.
disconnect alt pos wire
pull fuses and note any amp drop
good luck.
carefull amp meters average @10 amps max and could break if you try to crank engine.
Old Dec 7, 2022 | 03:53 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Most common drain that would pull battery down overnight is indeed a bad diode in the alternator. Yes it will still charge fine.
simple test. Remove large wire from alternator when you shut down the car. If your battery is still good in the morning you found your issue.
Old Dec 7, 2022 | 06:10 AM
Mr D.'s Avatar
Mr D.
Do a search here on parasitic battery drain, there are a number of threads outlining how to troubleshoot this.
Old Dec 7, 2022 | 08:09 AM
HeadsU.P.'s Avatar
HeadsU.P.
And in some cases there were the hidden light bulb constantly on.
On some models the bulb in a rear compartment.
Other models had a spare tire carrier courtesy light.
Unless your garage is pitch black, you would never know it was on.
Old Dec 7, 2022 | 08:59 AM
derekderek's Avatar
derekderek
Unplug small wire plug in alt also to ck for alternator drain.
Old Dec 7, 2022 | 10:42 AM
Catfish4818's Avatar
Catfish4818
Yep, this happened to me a couple of times. The lid in the center rear storage compartment wasn't fully closed and latched, causing the bulb in there to remain on.
Old Dec 7, 2022 | 03:15 PM
bobby70's Avatar
bobby70
ALOT good info and forgot to. say that I was trying to adjust the carb but no power to the chock and my friends speed shop hook it to the alternater never had a problem with it but its something else to check alot of good info so out to the garage and start checking thanks you guys bob
Old Dec 7, 2022 | 03:47 PM
ralphspears's Avatar
ralphspears
Banned Scam/Spammer
Is the wiper override switch turned off under the steering column
Old Dec 7, 2022 | 05:03 PM
HeadsU.P.'s Avatar
HeadsU.P.
An electric choke should ONLY be wired to IGN Switch On circuit.
Sounds like your friends wired it on continuously = parasitic draw, full time.
Old Dec 7, 2022 | 09:51 PM
bobby70's Avatar
bobby70
WELL went out to the garage and started looking around and the overide switch was off then unplug the alt and pulled all the fuse out and still getting power to the whole left side of the fuse panel this one will kick my ***
Old Dec 7, 2022 | 10:42 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
uh wut?
unhooking alt will not kill power to the car.
until you start with something between bat cable and bat to show the drain, nothing can be learned
Old Dec 7, 2022 | 10:53 PM
Bikespace's Avatar
Bikespace
OP:
Do you have a camera on your phone? Take some photos and post them (air cleaner assembly off). Perhaps we'll see something obvious.
Do you have a multimeter and know how to use it? Do you still have a power draw with ALL fuses removed? That's a useful data point, but you need to measure the current draw.
Old Dec 8, 2022 | 08:27 PM
bobby70's Avatar
bobby70
OK guys look around today found one problem but it was not the problem can some one just press the brake pedal car off to see if the brake lights come on I. have a friend. coming over on Friday to check the alt and diode but will that kill a battery in 3 hours thanks bob
To Dead again
Old Dec 8, 2022 | 09:49 PM
barkingrats's Avatar
barkingrats
1967 Pedal Car Champion
I believe your question is: Will the brake lights illuminate without key inserted or engine running? Yes. Emergency flashers, headlight bulbs, and side markers too.
I'd advise a battery cut-off switch for your car. Regardless of your current issue, you really should be cutting all power to the car when not in use to protect against a short-caused fire.
Old Dec 8, 2022 | 10:10 PM
Peterbuilt's Avatar
Peterbuilt
Default How to find a battery drain
https://www.corvetteforum.com/forums...with-pics.html
Yes, the brake lights will come on when the key is out.
Old Dec 8, 2022 | 11:22 PM
bobby70's Avatar
bobby70
ok great at least I know the rear lights not the problem ,I had this car 22 years put every thing new complete frame off rebuildi the ac complete wire harness never had a short have a 1000 w stereo I don't want to set up my sterno or clock every time I get in the car this is just me if the car is correct you don't have to unhook the battery the car was at the body shop for 8 month the clock was correct and it started right up when the snow flies it gets put away I don't unhook the battery but I still keep a battery tender on it plus plenty of insurance.if it burned to the ground then I will buy a c8
