Shark Bite rear suspension
Old Dec 7, 2022 | 09:38 AM
dmeesq's Avatar
dmeesq
Default Shark Bite rear suspension
So im pretty decided on putting a shark bite rear on, but i would really like to hear from those who already have and get your thoughts.
try to be unbiased.
im hoping not only will it improve the ride, let me lower the car some more, but I think it will look pretty cool on my car.
and PICS please.
thanks
Old Dec 7, 2022 | 10:15 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
So you don't care about handling? The stock rear suspension is better in my opinion. There is a lot that can be done to improve it without changing it. The shark bite looks cool that's about it.
Old Dec 7, 2022 | 10:28 AM
dmeesq's Avatar
dmeesq
thats what im trying to find out, is it worth it. is it an improvement on handling and ride height. id like to lower the car at least another inch but im pretty much at the bottom of my long bolts. and im looking for adjustability also. Keep in mind, my car is driven, but its almost exclusivly a show car.
Old Dec 7, 2022 | 11:55 AM
ignatz's Avatar
ignatz
Never understood what the perceived advantages of the Sharkbite conversion are. Springs and shocks, however implemented, have a singular characteristic, resistant force generated against displacement or displacement rate. How does Sharkbite go beyond that? The geometry and maybe some non-linearities, and moving parts all seem counter productive.
Old Dec 7, 2022 | 12:53 PM
dmeesq's Avatar
dmeesq
id like to get some replys from those who actually have shark bites.
Old Dec 7, 2022 | 06:40 PM
ddawson's Avatar
ddawson
Difference over a Fiberglass spring was not anything special. Ride height is easy and so is shock adjustment.
At least I can't tell a difference driving on the street on twisty backroads.
I use the hard spring and I make it bounce or a Cadillac depending on rebound or compression settings.
Ran into some issues with the install but nothing horrible. This setup doesn't address toe change either.
Old Dec 7, 2022 | 07:09 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
well its very spendy for one....
I do not have sharkbite....but I do have VBP tunable suspension front and rear. I can say that having a suspension that you can raise and lower without cutting anything and change the spring rate is worth it, but I would just go with a coil over conversion than their kit and reuse your bearing assemblies......atleast $1000 cheaper from van steel and you get 2" offset trailing arms out of the deal
https://www.vansteel.com/index.cfm?f...&subgroup=1957
The big difference of fiberglass springs over the steel ones is a significant weight reduction
Old Dec 7, 2022 | 09:47 PM
ddawson's Avatar
ddawson
Now that I'm home I can post a picture.
Old Dec 8, 2022 | 09:29 AM
Richard Daugird's Avatar
Richard Daugird
I think in your case, being mostly a show car, it would be worth doing. DEFINITLY looks cool! You may want to notch your rear crossmember while you are at it to maintain more level half shafts, I'm doing it with mine, I'm even planning air bags in the future for the low look plus drivability.
Old Dec 8, 2022 | 09:37 AM
509 rat's Avatar
509 rat
Default nice
Is that a 12 bolt and 3 1/2 inch half shafts with 1350 u joints .
Old Dec 8, 2022 | 11:54 AM
reno stallion
Stock style C2 rearend
Old Dec 8, 2022 | 12:06 PM
Richard Daugird
10 bolt? Stock style, yet highly modified?
Old Dec 8, 2022 | 12:25 PM
Rescue Rogers
Are the flex tube vents for rear brake cooling?
Old Dec 8, 2022 | 12:40 PM
reno stallion
3 series
Old Dec 8, 2022 | 12:41 PM
reno stallion
Yes
Old Dec 8, 2022 | 02:27 PM
509 rat's Avatar
509 rat
The half shafts stock I don't think so but ok be that way .
Old Dec 8, 2022 | 02:59 PM
dmeesq's Avatar
dmeesq
Did this turn into someone else's thread?
To Shark Bite rear suspension
Old Dec 8, 2022 | 03:50 PM
reno stallion
Well these thing happen on here but no it's all urine pee pee. All joking aside unless you just love the way the shark tooth looks it's not worth the money. Spend it on offset TAs and shocks and bigger wheels and tire's
Old Dec 8, 2022 | 04:52 PM
509 rat's Avatar
509 rat
Default yes
I agree in my opinion too many moving parts and with that angle on the coil over just to get to a 650 pound spring you would probably have to run 850ish to achieve the same .
Old Dec 8, 2022 | 05:39 PM
Richard Daugird
Reno’s setup is killer and definitely heavy duty, but as I said before that Snakebite setup looks awesome especially on a detailed show car like yours. You already have a pile of cash in that car may as well go for it. If I wasn’t planning air ride that’s how I’d go.
