Can somebody tell me in a 1977 Corvette does the glove box go on top of the rear door compartment or does it go underneath ? I just bought a brand new rear door compartment and I forgot it’s a glove box right on top of it or underneath it and then I bolted it in. I think it went on top of the door compartment frame. Thank you.
I have a 77. I've owned it many, many years so hopefully I can help.
first off, 77's do not have a glove box. They have a map pocket. Later C3's have a glove box. In the rear storage area are 3 compartment doors. Far left is the battery compartment sealed with a foam strip around the door. Then there is a center storage compartment and far right is the jack storage compartment. In the jack storage compartment is a tray that sits on top. And is removable with the door open.
Is this the compartment you are referring to???
The center compartment has a cardboard box/tray that's is below the door frame and is not removable.
I am happy to take photos of my car. But just unclear as to what you need as a 77 never had a glove box.
yes, I meant to say that. yes, its the jack storage compartment. Does it go under the door frame or sit on top?
The tray in the jack storage compartment, far right. Sits on top. So it is easily removable to access the jack and lug wrench/jack handle in the event of a flat.
