Lock Washers needed?
Old Jan 6, 2023 | 12:50 AM
mbp's Avatar
mbp
Default Lock Washers needed?
Hello. As the title says are lock washers, external, split, or flat washers needed on the two bolts and two nuts that bolt the carburetor to the intake manifold. It's a stock iron manifold if that makes a difference. Trying to stop them from having to be retightened or end up over tightened. Thanks for your helpful advice.
Old Jan 6, 2023 | 05:43 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Pleasse dont buy china-etc brands...they break in half afte heat cycling!
Old Jan 6, 2023 | 09:02 AM
KS69Coupe's Avatar
KS69Coupe
Try Richard Fortier at (810) 750-1472
He has faseners that are excellent quality. No China or repro junk.
Old Jan 6, 2023 | 09:35 AM
HeadsU.P.'s Avatar
HeadsU.P.
I use a stainless flat washers to clamp a Holley to aluminum Intake. The washer keeps the nut from gouging into soft materials such as the carb base.
And in a small way the washer distributes the torquing load evenly.
When torquing down any carb base, crisscross the tightening pattern in several steps.
Old Jan 6, 2023 | 11:27 AM
MelWff's Avatar
MelWff
Since you are referring to a Quadrajet they use flat washers only.
Old Jan 6, 2023 | 01:37 PM
Sayfoo's Avatar
Sayfoo
"two bolts"????
If your bolts loosen up enough that the carb is loose (not just the gasket compressing) without lock washers, why not try lock washers??
Old Jan 6, 2023 | 04:08 PM
OldCarBum's Avatar
OldCarBum
If you feel you need a locking device on the carburetor stud nuts and don’t want to use lock washers, try using a good nylon lock nut with a flat washer underneath or use a little Locktite on the threads.
Old Jan 6, 2023 | 04:58 PM
sunflower 1972's Avatar
sunflower 1972
Photo taken 6 months after I bought it in 2015. Carb mounting bolts with flat washers. At the time I took the photo, with the exception of the thermostat housing, everything is original.
To Lock Washers needed?
