Starter???
Old Jan 7, 2023 | 07:34 PM
69FASTFUN's Avatar
69FASTFUN
Default Starter???
I have a questions on starters. I am restoring a 72 that was an automatic and converting to a 5sp. is there a difference between a automatic starter and a manual starters.
Old Jan 7, 2023 | 10:07 PM
Mooser's Avatar
Mooser
There is a difference in the stock th400 starter and the 4sp starters so I can only assume there would also be to the 5sp. Most likely to do with the tooth count on the gear that anything else but I'm not sure on that.
M
Old Jan 7, 2023 | 11:30 PM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Different gear count starters mount differently that much I know. A lot of these mini starters come with a bunch of mounting holes so they apparently fit just about everything.
I guess the big difference will be in the tooth count on the ring gear.
Old Jan 11, 2023 | 08:50 AM
stingr69's Avatar
stingr69
The manual starter has a cast iron nose cone. The automatic starter uses an aluminum nose cone. They are not interchangeable.
I really like the Delco PMGR starter with the special bolts. I tried a remanufactured stock starter but it had an aftermarket replacement nose cone. I could not get it to work right so I tried the Delco PMGR. It is 100% new, weighs a LOT less and works great. About $100 or so from places like Rock Auto. If they do not put the special bolts in the box for you you can PM me for a pair. There is no "lookup" for the part but if you are interested in the part number, just ask and I will post it.
To Starter???
