Dipstick length .
Old Jan 11, 2023 | 06:02 PM
Gavin65's Avatar
Gavin65
Default Dipstick length .
I have a question for the collective , what is the correct length Dipstick for a 1984 vintage 454 block. I have read that it’s 23.5 inches , however the current dipstick is 23.5 inches and with a full 6 quarts in the pan there is no reading of oil on the stick. I tried to use the dipstick out of my 427 but it is quite a bit longer than the one in the 454, it also would not seat within the dipstick tube (too long)
Old Jan 12, 2023 | 08:23 AM
7T1vette's Avatar
7T1vette
The problem may not be the dipstick. The dipstick TUBE needs to be the correct length for the 'correct' dipstick to read properly. You may have a tube that is too long. Bottom line: the dipstick "parts" need to work together so that the FULL line on the dipstick is set at [about] the oil pan split line position. Depth of counter-bore (for the tube) in the engine block, length of tube and dipstick dimensions are come into play.
Old Jan 12, 2023 | 03:28 PM
Gavin65's Avatar
Gavin65
agreed, I found out what the issue was, the pan with a full filter holds a total of 7 qts, it only had 6 qts when I checked it, and there was only a small dot of oil on the stick, thanks for your response.
To Dipstick length .
