Power Steering
Old Feb 10, 2023 | 10:51 AM
Stroker3414's Avatar
Stroker3414
Default Power Steering
Looking to add power steering to my 69. It’s manual now. I see ZIp offers an electric version and a more conventional type Borgeson. Anyone here have pros and cons about either one.
Old Feb 10, 2023 | 11:51 AM
MelWff's Avatar
MelWff
Not interested in the OEM version?
Old Feb 10, 2023 | 12:09 PM
Stroker3414
I did’t want the hassle of possible more leaks
Old Feb 10, 2023 | 12:58 PM
OldCarBum's Avatar
OldCarBum
First, I would talk with Gary Ramadei (GTR1999) about rebuilding your oem steering box.
You may find that just having Gary rebuild your oem box, may be all you need.
I looked at several electric assist steering systems and the biggest problem is always where is there room to mount the system.
Some mount up under the dash, but where is there really room, and some mount in the engine compartment.
Several members have gone to manual and power assist rack and pinion systems with great success.
The Borgeson steering box is another great option that I was originally going with.
I purchased the Borgeson box, a Tuff Stuff ps pump and a Billet Specialities remote fluid reservoir.
It would have been a nice set up.
One thing to consider is the size difference between the oem steering box and the Borgeson box.
Additional items to think about are:
You’ll need to purchase a new drag link, pitman arm for the steering box, power steering pump and brackets, maybe an alternator bracket as some year model or big blocks are a combination of the two, engine and pump pulleys and other items.
I ended up pulling my power steering, converted it to manual and had Gary rebuild my steering box.
Old Feb 10, 2023 | 01:26 PM
Stroker3414
Where is Gary located?
Old Feb 10, 2023 | 01:47 PM
MelWff's Avatar
MelWff
connecticut
Old Feb 10, 2023 | 04:59 PM
Bikespace's Avatar
Bikespace
A few folks have electric steering pumps with the Borgeson unit, and it looks like I'm going that way in my 79. Even with a belt driven pump, the Borgeson is great in that car.
@Richard454 has an electric assist unit in his lightly modified car, a quick search should find a thread or two.
My 80 was converted to manual steering with a @GTR1999 rebuilt box. That's also great, for that car.
It's not worth shipping the original power steering bits, but I have them somewhere.
Old Feb 10, 2023 | 05:42 PM
Golfobsessed's Avatar
Golfobsessed
Just throwing it out.... Borgeson is a very easy installation and fantastic power steering, slightly quicker than stock.
installed mine in a Saturday afternoon, easy $1,000 investment
Old Feb 10, 2023 | 06:24 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
that would imply you bought junk rebuilt parts from vendors who have no clue. Or installation errors.
Old Feb 10, 2023 | 07:11 PM
Stroker3414
Or that a car built in 1969 is prone to leak from time to time. I get your comment…but I don’t buy cheap parts…thus the reason to get on a forum to get suggestions from other people who may have already had success…
Old Feb 10, 2023 | 07:19 PM
Bluesting70's Avatar
Bluesting70
2024 Corvette of the Year Winner - Modified
2023 C3 of the Year Winner - Modified
I did the stock rebuild. Not as good as I thought it would be. And yes, it was all done right with quality rebuild. If I do it again, it will be the Borgeson upgrade. Kicking myself for not doing it.
wolfk's Avatar
wolfk
I just completed a borgeson power kit install on my factory manual steering car. Like Golfobsessed said, it's a fairly easy install. You re-use your existing pitman arm and drag link.
Old Feb 10, 2023 | 08:13 PM
Nowhere Man
was your steering box rebuilt correctly?
Old Feb 11, 2023 | 06:36 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
A properly done stock system works incredibly well.
And a borgeson conversion is just putting jeep steering in a Corvette.
To me, that's all kind of wrong.
To each his own. But the borgeson system uses a pump and hoses as well. So there is still the possibility of leaks.
Old Feb 11, 2023 | 08:08 AM
Stroker3414
So being at the beginning of this endeavor…a few of you have talked about a “steering box rebuilt correctly”, what do you mean by that?
Old Feb 11, 2023 | 08:18 AM
Bikespace's Avatar
Bikespace
The manual steering box can be rebuilt to like new, or to better-than-new specs. For my manual conversion, I used a steering box that was rebuilt by @GTR1999, and @4-vettes recently documented his DIY rebuild.
That probably won't "fix" your problem if the problem is that you need power steering. But it will make the steering much more precise, and when rolling down the highway the car may be much more pleasant to drive. I believe the electric assist system also relies on the stock steering box.
The Borgeson replaces the stock steering box. It has half as many hoses to leak and a quicker turning ratio. One issue with the Borgeson is that the box is larger, and may require clearancing for some header/engine combinations.
Old Feb 11, 2023 | 08:25 AM
Stroker3414
Thank you, now I understand. I have a 427 bb so there isn’t a ton of room to work with. When I researched the electric system it requires cutting the steering column too. Maybe my first run at this is to have the box rebuilt and see how that works.
Thanks to all for the information, it was very helpful!
To Power Steering
Old Feb 11, 2023 | 08:43 AM
Nowhere Man
just watch where you send the box to. Many just clean out the old grease and put in new and paint it and send it back. There is way more to it then that.
Old Feb 11, 2023 | 10:01 AM
Stroker3414
Good advice, are you aware of anyone in or near Colorado who you could recommend?
Old Feb 11, 2023 | 10:08 AM
Nowhere Man
Gerry in Ct that was mentioned in this thread and a member on here or Bairs Corvette in Pa. Sorry I don’t know anyone out west. I know there is a few places in the mid west but correctly and rebuilt is not in there description
