Front spring replacement
Old Feb 18, 2023 | 11:34 AM
Golfobsessed's Avatar
Golfobsessed
Default Front spring replacement
Hey guys, normally I wouldn't have a concern, replaced many front end springs in my life but never seen such a difference in length from the stock springs to the replacement springs, the stock springs I just removed are about 3" linger than the replacement 475lb springs I have and the part number shows correct, is this common and will with spring rating make up the difference
Popular Reply
Feb 18, 2023, 04:28 PM
Golfobsessed
Done, based on prior spring replacements and feedback from this group I knew the replacement springs would sit a bit higher than I wanted and didn't want to keep installing and measuring if possible... I took just about 1/2 coil off (maybe just shy of a half coil) and split the difference between top and bottom of the spring to start with and sits where I want it... would have been too high for sure for me.
Old Feb 18, 2023 | 12:17 PM
jhudec's Avatar
jhudec
Lots of discussions on the forum regarding springs. After market are heavier coils and thus the spring rate may or may not let your car sit correctly, normally the issue is with after market springs it sits too high. Some guys need to cut coils to get desired high.
I am sure there are some out there that give the correct height.
I tend to stick with the oem springs.
Joe
Old Feb 18, 2023 | 12:25 PM
Golfobsessed
Joe
thanks Joe, found some older threads and appears the 3" difference is pretty common, just got one side done, heading to the other. Thanks again
Old Feb 18, 2023 | 04:28 PM
Golfobsessed
Old Feb 18, 2023 | 06:31 PM
Mooser's Avatar
Mooser
M
Old Feb 18, 2023 | 06:42 PM
jodfit's Avatar
jodfit
St. Jude Donor '07
Good God! That is a STUNNING car!
Old Feb 18, 2023 | 06:57 PM
Golfobsessed
thank you
Old Feb 18, 2023 | 08:37 PM
sunflower 1972's Avatar
sunflower 1972
Looks good!
Old Feb 19, 2023 | 07:01 AM
540 vette's Avatar
540 vette
I had the same problem with front coil springs. Couldn't get the ride height I wanted. Must have taken the springs in and out a few times. After ruining a set of springs I bought coil overs and set it where i wanted it.
Old Feb 19, 2023 | 08:34 AM
Golfobsessed
I did consider that but didn't want to modify too much as the car is pretty original. There is a rule of thumb when cutting springs... free height spring cut gives twice the drop so 1/2" spring height cut gives 1" drop and worked perfect first time, took about a 1/4 coil off each end of the spring before installing, sits exactly where I want it, matches the rear and no difference in the ride at all... took it out for a while and measures 27.5" on all four corners, I got lucky.
I purchased two sets of springs (I have a friend who works for an auto parts house so wasnt expensive) just in case I went too far.
Old Feb 19, 2023 | 08:40 AM
Bikespace's Avatar
Bikespace
When I switched to 550s, it lowered the front of the car a bit, but not enough. I don't want to mess with the coil angle if I cut them, so when I take them out again, it will be to install semi coil-overs. It sounds like you got very lucky.
Here are the two springs (the long one is the original, 80 L48 4-speed)
Old Feb 19, 2023 | 08:51 AM
Golfobsessed
I've always used that "half length to drop" and it's always been pretty accurate, i was a bit surprised on the replament springs to originals length difference (same as yours above) so was a bit reluctant to cut.
Old Feb 19, 2023 | 05:04 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Did it have a full tank of gas when you measured the Rear height?
Just wondering if the rear sits lower than the front after filling up.
Old Feb 19, 2023 | 07:31 PM
Dino_'72's Avatar
Dino_'72
thank you
Wow. I’m usually a factory rally wheel look type of guy but those TT IIs look awesome. They like gray with polished rim?
What size wheels and tires ?. Backspace front and rear?
After 30 years maybe I need to swap out my rally’s.
Wish I could offer help on the springs I replaced mine years ago with Moogs height more or less stayed the same. Good luck.
Old Feb 19, 2023 | 07:48 PM
Golfobsessed
I didn't really take notice of the rear height and gas tank level... the above pics are with about 5/8ths of a tank, pretty even all around, standing at a side profile there is about the same wheel well gap all around.
Old Feb 19, 2023 | 07:59 PM
Golfobsessed
thanks... springs worked out perfect.
I originally purchased a Torq Thrust wheel package from "wheelsforless" as a C3 package... what a disaster that was, wrong wheels all together and was a bad experience.
I went to Discount tire and purchased the correct Torq Thust wheels 15x8 gray low gloss center with machine finish outer lip, 3.79 backspace (-18mm offset) VN2155861us is the part number and 255/60/15 tires, actually cheaper than the "wheelsforless" package at just a bit over $1500 for everything mounted and balanced out the door.
Discount even mounted one to let me take home and check clearance.
Old Feb 20, 2023 | 02:04 PM
Dino_'72's Avatar
Dino_'72
Thanks for the detailed response that includes part numbers. Those TT IIs and side pipes in orange give your car a racer look. Looks awesome. Thanks again.
To Front spring replacement
