interior door lock knob
Old Mar 15, 2023 | 02:37 PM
VinniePG's Avatar
VinniePG
Default interior door lock ****
I have a 1975 and am trying to install the door door lock *****. i bought replacement panels. I was able to get the passenger side **** back on with no issues. Having a difficult time with drivers side. I have used the mallet and hammer to no avail. It looks like the whole is not centered enough. the bottom of the hole is close to the spline. What is the best course of action? should I dremel out a little of the hole on the bottom? any suggestions, greatly appreciated.
Old Mar 15, 2023 | 02:40 PM
walleyfisher's Avatar
walleyfisher
losen up all the door panel screws
Old Mar 15, 2023 | 03:38 PM
62corvette's Avatar
62corvette
I have enlarged the whole toward the offending side. With the bezel, you have some room to spare.
Old Mar 15, 2023 | 04:34 PM
HeadsU.P.'s Avatar
HeadsU.P.
Besides removing some panel material for clearance, check to see if the "C" clip retainer is allowed to flex a little. Could be GM clips or aftermarket.
If the clip will not budge to allow engagement, no mallet will be big enough to force the **** in place.
With the clip / retainer installed on the ****, insert a flat blade screwdriver to check for clip movement.
Old Mar 15, 2023 | 05:11 PM
Hamdifnruj's Avatar
Hamdifnruj
Banned Scam/Spammer
have you losen all the panel door screws?
To interior door lock knob
