Steering column wiring connector
Im refurbishing the T/T steering column without tearing it apart.
My question is, it appears that the wiring connectors on the column may have an “extra” pigtail extension wire added to the factory connector.
It looks to me like an add-on, but I cannot figure out what would be its purpose.
The main factory wiring connector coming out of the column is marked with a red arrow. The possibly “added” pigtail connector, marked with a green arrow, snaps into the factory connector, then about 6”-8” of wire then another connector (marked with the orange arrow, that connects to the dash wiring harness connector.
Is this something a PO added, or is this something the factory installed so a common steering column could be used on multiple optioned vehicles simply by installing the correct pigtails?
Or something altogether different?
thanks
The Green Arrow connector is representing the main dash harness connector.
Sometimes when a earlier or later switch was installed a adapter harness was needed.
My opinion anyways...
M
CC shows it as 69-76 with T/T but I'm pretty sure my 72 didn't have it... Maybe it was supposed to...
M
So I removed the steering wheel, T/T locking ring and metal cup and taped up ignition switch and hazard light switch.
I primed parts and column with self etching primer and then 2 top coats of satin black paint.
I’ll be damned that the paint only adheres good to the metal on the steering column itself.
The plastic housings on the column as well as the metal cup under the steering wheel did not fare as well.
After nearly a week of cure time, the paint will scratch off down to the original color.
Rookie mistake! I did not scuff or prep parts with acetone or paint thinner first.
I KNOW BETTER!!
Time to sand it back off.
For my second attempt, any other words of wisdom before I try again?
Rattle can spray pain ok for the column, or should I get the dye?
TIA
I KNOW BETTER!!
TIA
I used the interior dye (several coats) and then topped that off with a clean primer (several coats) as keys are notorious for scratching the column.
I guess I’ll plan to start sanding on it to remove the “fresh” paint.
Better now than later, after I get the car back together…..
