Time for a paint job.
I going to try the razor method, but it's not turning out the way I see on u-tube. I've tried different blades, different handles, and the image below are the best results. The primer colour is tan and the finish colour is navy blue as seen in the first image. I'm having a hard time getting underneath the clear coat, but am in no hurry, as my main goal is not to damage the fiberglass.
My process will be:
remove paint with razor.
orbital sander to primer with 60 grit.
Orbital sander to fiberglass with 120 grit.
Block sand with 220 grit.
Block sand with 400 or 600 grit.
Not sure about the tru-flex bumpers, but maybe just a light sand.
I haven't figured out my budget for all materials, but I'm thinking around $1,500.00 to $2,000.00 Canadian dollars, depending on which finish I go with.
Before: Don't let the photo fool you on the paint as it's not as good as it looks.
I'm starting at the passenger top fender.
Popular Reply
I can't speak to removing paint on a Corvette but 36 grit seems a bit extreme. Easy to burn thru into the fiberglass.
So on the last couple of hot rods I've done I stripped them to the bare metal including my 68 C10 frame off. Skim coated filler on all panels and sanded 99% of it off. Started with 80 grit then 180 grit and then 320 grit on long or short blocks as needed. I did all the block sanding by hand. The body shop owner being the nice guy he is said I don't have the skill for power tools. Then "poly" spray filler and sand most off that off. 180 grit and 320 grit. Then two coats of epoxy primer with a guide coat to get everything really straight. 180 grit first and then 320 grit on a block and then 320 on a DA with soft pad.
After paint the body shop guys wet sanded and buffed all the panels. Again they did it because they didn't want me to sand or buff thru the edges.
Prior to my 68 C10 I've never done any body work.
My 68 C10 had $3500 USD worth of materials and that was 5 years ago. I'm guessing today 50% more material wise. Pic of my 68 C10.
Watch the colors as you sand, and immediately stop sanding an area when you break thru the paint.
Back in the day, we used 8” orbitals with 36 grit for removing old paint on steel cars, and it really sheared that paint off in a hurry.
On my current car I did the razor blade method for most of the car, and I am so sorry i didnt use it years ago on the others. I thought removing paint on a vette with razor blades was insane and would only make more work. Just the opposite, once I got the feel for it the paint flew off the car.
On the rubber bumpers I only used scotch brite pads and lacquer thinner along with lots of elbow grease down to the bare surface. Took forever but did a nice clean job.
Lots of work but worth it. Good luck.
Thanks for all the replies.
Billenglish
The garage is presently 40 degrees F, even with the heater on, I don't believe a heat gun would be very effective.
CorvetteMike2004
I find the razor makes much less mess and is faster and more cost effective.
wwiiavfan
After I complete the razor stripping I'm going to try a 120 grit orbital sander.
Richard Daugird
Yup, it is a bit too late, but I always strip the car before any paint job.
John 65
I'm not sure what I'm going to do when it comes to the rubber. Maybe something to think about.
forman
Thanks for the information.
Thanks for a run down on the process. You had a good budget. Mine will be less than half that.
40 degrees in your shop you must keep moving to stay warm? LOL.
Good luck with your paint project.
I know it's not a good picture as someone else took a picture of me and the Vette happened to be in it.
I'd estimate that approximately 80 hrs have gone into the prep. Approximately 30 of those hrs. were spent removing trim, adjusting headlights, hood, doors etc, removing spoilers, fiberglass repairs, adjusting new bumpers etc.
Still haven't selected which shade of dark blue metallic colour. I know what I want, but don't know the name or colour code.
There's no comparison between looking at a book of paint chips vs seeing the right color on a car in the sunlight. Good luck with it!
