E69 Front Grill - Paint
I could also jump over to the NCRS message board and post there as well. Thought I would try CF first. Thank you in advance for the help.
https://www.corvetteforum.com/forums...ont-grill.html
http://www.carpictureworld.com/chevr...-1200x800.html
https://www.corvetteforum.com/forums...ea-1968-a.html
Hi PJO,
As usual, you have once again come to my rescue. Links and photos are a big help. Looks like silver front half only edges on all 5 of the horizonal slats or fins that connect and intersect to the parking lamp beveled surround, along with the front half only of the parking lamp beveled surround itself. Not sure about the correct terminology but hope that this description makes sense. Looks like the outside grill edges all the way around the grill are semi-gloss black along with all of the vertical supports. Easy enough to mask the front half of the horizonal slats or fins at the molded part lines. I assume that this same paint scheme would apply to the center grill behind the license plate too...silver on just the front half of the horizontal sections and everything else semi-gloss black.
I will post some after pics in the event that I can help someone else down the road with their E69 front grill paint.
Very grateful for all of the continued help and support you have given me during this restoration. Thank you friend
Kind Regards,
Kevin
Center grill bottom view. Thought it was interesting that the center grill has the 1968 style horizontal bars while the LH and RH outer grills are the 1969 style horizontal bars where the bars are flush with the edges of the frame.
There was OEM evidence of silver paint on just the front half of the lowest five horizontal bars so that is what I am replicating.
Not sure what is most restoration correct but the edges of the OEM horizontal bars did not have silver paint on them when I stripped off some of the old paint so I'm restoring them like they were
Same thought process for the LH front grill and only masking the lowest five horizontal bars.
Finally, these outer front grills are a pain to mask off.
I would certainly take more photos. PJO was kind enough to provide some pics so I had a starting place. I will shoot you a PM with my email address. Makes no difference to me whether you post some more photos here or to my email addrress, whatever you prefer. Your call.
Your pictures are a big help. Couple of enlightenment "aha" moments for sure on my end. I was going to spray with Corvette Central medium gloss black but now thinking the Corvette Central low gloss black would be more accurate based on your pictures. Of course, after 55-years it could be just some fading and aging with time that causes the black in your photos to look more like low gloss, almost flat black. I'll check my NCRS book again in the morning to see if there is something spelled out in terms of the black finish: gloss, semi-gloss, flat. I see what you mean by kinda sloppy. I can replicate that pretty close I think since I sprayed the silver first.
I'll post some final pics when I finish to see what you guys think.
Thank you for the pics.
Kevin
I personally think the 68 grilles were used throughout the whole production year and into 69 until some point. My guess is the dealers complained about having to replace them at some point and they eventually redesigned them in 69, which then became production and standard service replacement. But that takes a bit of time which is why my theory is the 68 style made into 69. Just a hunch.
Also as you know these were molded in black plastic, not painted black so having looked at NOS replacements my eyes see a more semi-gloss black.
Post some pics of your finished job and have a pleasant weekend! AJ.
