red stuff
Apr 22, 2023 | 01:56 PM
red stuff
76 corvette small block. Red fluid on garage floor under front drivers side of car. what is source and what is the remedy? thanks.
Apr 22, 2023 | 02:01 PM
Power steering? Automatic transmission? Forgot you had a jelly donut in your back pocket and laid on the garage floor? Raspberry filled of course. Grape is purple...yeah ive done that.
Sounds like power steering fluid.
Could be the control valve, hoses, pump...
Apr 22, 2023 | 02:05 PM
St. Jude Donor '22
I say trans. unless tran fluid replaced power steer fluid.
drv side sounds like dipstick at trans pan is leaking?
Apr 22, 2023 | 02:15 PM
Quote:
Originally Posted by
calwldlife
Dipstick is on the right side...
Apr 22, 2023 | 02:24 PM
St. Jude Donor '22
yes.
pan then
Apr 22, 2023 | 03:46 PM
Car has power steering AND automatic transmission.
Apr 22, 2023 | 04:21 PM
PS leak, look at the control valve / cylinder area and see if it's wet.
Apr 22, 2023 | 04:26 PM
Are power steering fluid and trans fluid the same color?????????
Apr 22, 2023 | 04:39 PM
Hello, generally, no, they are NOT the same color, however, some people substitute ATF [which is reddish-pink] for power-steering fluid. That is possibly your situation Regard, LowSporty
Apr 22, 2023 | 05:35 PM
Thanks. What color is power steering fluid?
Apr 22, 2023 | 05:47 PM
Very lite yellow, almost clear.
Apr 22, 2023 | 08:28 PM
And what color is auto trans fluid? Fluid on floor is red.
Apr 22, 2023 | 09:01 PM
Apr 22, 2023 | 09:21 PM
Cruise-In VIII Veteran
Well, ya know. The first place I would look is directly above the puddle!
drivers side, front of engine.
Power steering.
Apr 22, 2023 | 09:32 PM
riverracer au
pictures would help...
If it's red, it's probably automatic transmission fluid. There is a cooling loop that goes through the radiator on the starboard side.
Or perhaps someone put ATF in the power steering system. I s'pose Jim Shea could tell by taste, but for the rest of us, photos would help.
The best solution to either problem is to replace with the manual equivalent, steering, transmission, or both.
Apr 22, 2023 | 09:51 PM
A slight chance it's the front seal on the transmission then dripping towards the outboard side.
Slight chance it's the shift cable shaft seal.
Slight chance it's the "O" ring on the bullet for the speedometer cable and driven gear. The cable takes a slight dip before it rises to the firewall.
Good chance it's the trans pan gasket, left front corner.
At any rate, there is a dye you can introduce to the ATF or PS and a black-lite will verify the leaking source.
