C3 Lazy eyes mod
Old May 3, 2023 | 09:41 AM
StingrayBob's Avatar
StingrayBob
Default C3 Lazy eyes mod
Hi folks.
Anyone done this type or similar Lazy eye headlight "upgrade" on a C3..?
My C3 is a mild restomod & not matching numbers -73 convertible, and I might be looking in to something for the headlights.
Popular Reply
May 3, 2023, 01:51 PM
Richard454's Avatar
Richard454
Something like this?
Old May 3, 2023 | 10:20 AM
RetroGuy's Avatar
RetroGuy
Be careful with this Lazy Eye mod on an early C3...could come out lookin' like Pink Eye
Old May 3, 2023 | 10:31 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
IF I win the lotto I would go with equal size "bulbs"...of course since I have night vision like an owl, I've never had a problem with lighting.
I WILL do the headlight wiring relay mod just for fun/safety, though.
Old May 3, 2023 | 11:24 AM
Tranz Zam's Avatar
Tranz Zam
I've seen a few done, and it looks pretty cool. They usually use 2 cubes or 1 rectangular led lights per side. Just looking at the assembly, it shouldn't be hard at all to limit the travel of the headlight door assembly. Just gotta figure out the mounting points for the new lights.
Old May 3, 2023 | 01:38 PM
wwiiavfan's Avatar
wwiiavfan
Actually I think it would be a bit of a challenge. C3 headlight mechanisms are designed to go “over-center” at full opening, so they will stay open on their own without vacuum. I don’t know if that’s achievable at partial opening.
Old May 3, 2023 | 01:51 PM
Richard454's Avatar
Richard454
Old May 3, 2023 | 04:49 PM
Tranz Zam's Avatar
Tranz Zam
You could pretty easily limit the travel, especially if you're converting to an electric setup. I wouldn't go through with converting to sleepy eyes and keep the vacuum setup.
Old Aug 26, 2023 | 08:56 AM
mpguidry's Avatar
mpguidry
who makes this setup?
Old Aug 26, 2023 | 10:48 AM
Jarhead 74 Vette's Avatar
Jarhead 74 Vette
Veteran: Marine Corps
Great idea!
I really like this setup you show here, Richard.
Do you know who makes this and will it work well with the electric setup I bought from you?
Old Aug 26, 2023 | 10:53 AM
6 Shooter's Avatar
6 Shooter
Scott does…
https://www.restomod-tech.com
Old Aug 26, 2023 | 02:40 PM
sonksen_design's Avatar
sonksen_design
Thanks for answering the question as to where C3 owners can find this product. I'd offer more to say, the the CF moderators are pretty strict on what 'businesses' can say. Shows how often I'm on CF... I never saw the thread start from 5/3/23. Happy to report that my patent filing was finalized recently.
Old Dec 5, 2023 | 07:54 PM
sloC3's Avatar
sloC3
1st Gear
I just got started making some, I need to make some shrouds, but this is the prototype so far…
Old Dec 5, 2023 | 08:29 PM
sonksen_design
sloC3- I like your version so far. Be aware of patent laws if you plan to sell this as a kit.
Old Dec 5, 2023 | 08:50 PM
ignatz's Avatar
ignatz
None of these alterations look at all attractive. Take a look at the "Green Mamba". One could imagine a reveal by tilting the headlight door down in back to expose the lights there. Probably more aerodynamic too for what that's worth.
Old Dec 5, 2023 | 09:46 PM
SteveG75's Avatar
SteveG75
I thought all C3s already had lazy eyes. One headlight comes up first and then the other one.
Old Dec 27, 2023 | 04:18 AM
NickC3's Avatar
NickC3
4th Gear
How did you adjust the height of the lid? When I adjusted mine down to the height I like, it closes too low or the electric actuator won’t spin properly and gets stuck.
Old Dec 27, 2023 | 09:32 AM
Richard454's Avatar
Richard454
You are changing the throw- the length of the arm needs to be changed.
Not if the Chinese knock it off...just sayin
To C3 Lazy eyes mod
Old Dec 27, 2023 | 07:01 PM
NickC3's Avatar
NickC3
4th Gear
Are you referring too the bracket that’s attached to the motor? (bottom arrow). Or the adjustable eye bolt (top arrow)? I adjusted the top one, even cut it to shorten it so there is less travel hoping to shorten it opening. But when I did it, I guess the rotation was limited not allowing the bracket (bottom arrow) rotate at a full spin. Maybe I did it too short. Please confirm which one to work with. Thank bro
Old Dec 27, 2023 | 08:01 PM
Elcransonator's Avatar
Elcransonator
Originally Posted by StingrayBob
Hi folks.
I think that is called the Forest Whittaker mod
Old Dec 27, 2023 | 09:40 PM
sydvicious12's Avatar
sydvicious12
Looks like expensive mod to make your C3 look worse.
