That's actually a cool solution. You could just leave your key in the ignition switch, and only use the fob, as long as you assume a thief wouldn't be able to figure out how to bypass it.
There's no chance I would trust that particular switch, but it is a nifty idea.
I get this. If the disco switch is to protect from extended periods of disuse, install the manual lever, leave the drivers seat folded forward when done and you'll always have the visual cue to reconnect it before you sit down again!
True and yes that works sometimes.
Other times when I take my wife, walking out to the car I start hearing "does it have gas?, did you lock the door?, did you pay the water bill from February of 2014?, what is the air-speed velocity of an unladen swallow?, etc."
Those are the times I just slam the seat back, yell "just get in the car woman", then look like a dingus when I have to get back out to turn the battery on...
