coil spring squeaking
Old Jun 2, 2023 | 05:15 PM
cabman72's Avatar
cabman72
Default coil spring squeaking
My left front coil spring started squeaking on my 72. How can I stop this? Is there suppose to be a pad under the spring? I'm sure its the spring because I had a friend bounce the car up and down and I felt the squeak vibration on the spring and lower control arm and nowhere else.
Old Jun 2, 2023 | 06:43 PM
interpon's Avatar
interpon
Bushings? Shocks? No cushion on mine
Old Jun 3, 2023 | 02:19 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Nope, no cushion on the spring. Guessing A arm bushings.
Old Jun 3, 2023 | 06:38 AM
1860army's Avatar
1860army
Lube the Ball Joints.....
60
Old Jun 3, 2023 | 07:49 AM
Tampa Jerry's Avatar
Tampa Jerry
Check to see if the spring is installed correctly. Is it binding and hitting the frame? Jerry
Old Jun 3, 2023 | 08:46 AM
wolfk's Avatar
wolfk
Or upper shock mount not centered, therefore, shock stud contacting and rubbing on inner edge of frame mounting hole. This situation I find on many cars with front end squeaks.
Old Jun 3, 2023 | 09:20 AM
cabman72's Avatar
cabman72
Thanks for the replies, here's a little more info: The car is a newer rebuild. control arm bushings, sway bar bushings, shocks and ball joints are newer. At highway speed there is no squeak, it only squeaks at low speeds and it is a metallic squeak. I'm going to remove the wheel and upper ball joint and look for bare metal where parts are rubbing together. I'll post up my findings.
Old Jun 3, 2023 | 12:14 PM
Sayfoo's Avatar
Sayfoo
Urathane bushings???
Notorious for squeeking.
Try squirting oil/lube at 1 joint at a time to isolate which joint is making the noise.
Old Jun 3, 2023 | 01:48 PM
interpon's Avatar
interpon
Sway bar links can make noise
Old Jun 3, 2023 | 11:27 PM
cabman72's Avatar
cabman72
I'll found the problem. After tearing everything apart and removing the spindle, coil spring and all that goes with it, I found the nuts on the upper control arm weren't tight and the squeal was coming from the shims! Tightened the nuts and all is quiet. Took about 3 hours to do a 5 minute job! Oh well, glad it is done!
Old Jun 4, 2023 | 12:22 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Quote: Took about 3 hours to do a 5 minute job!
I KNOW the feeling!
To coil spring squeaking
