1980 California
Old Jun 17, 2023 | 01:47 PM
stox258's Avatar
stox258
7th Gear
Default 1980 California
I have a 1980 California spec car with a Rochester E4ME carb in the UK. I have had a real problem with it later after I had to put in E10 petrol. I got a rebuild kit for it and changed all the seals, replaced all the |E10 with E5 and it now appears to run OK apart from the idle.
I have a few questions, in the picture above it shows a very small bore vacuum pipe (circled), that is sucking, but i am not sure where it goes. There is also an earth strap (square) that I can see but does not obvioulsy connect to anything. There are also 2 resitors/capaciors (not sure) that don't appear to do anything and also one appears to be broken? Any ideas?
I am also after a dwell meter to test the Solenoid switch on the carb and also the distributor dwell angle, what is the best one (as cheap as possible) that I could get in the UK and use to check?
Any help would be gratefully received.
Old Jun 17, 2023 | 02:39 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
vac hose should feed interior
last circle hooks to dist wires cover.
middle circle cat make out.
you need a meter with 6 cyl scale at least
Old Jun 17, 2023 | 04:22 PM
stox258's Avatar
stox258
7th Gear
Vac hose should feed interior where?
Actually to the distributor cover where?
Any ideas on a meter, make/model?
Old Jun 17, 2023 | 08:49 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
enters by big electric gromet center of firewall
pre owner must have tossed it out
https://www.ebay.com/itm/125854685554
there are too many,
usual engine dwell electrical testing equipment
https://www.amazon.com/dwell-meter/s?k=dwell+meter
Old Jun 18, 2023 | 04:32 AM
stox258's Avatar
stox258
7th Gear
I have looked on line at meters but they only seem to show the Corvette from 1981. They say the ALDL connector is under the ash tray but it isn't.
Did the California version have the "Computer Command Control" system with the ALDL interfaces to the Engine Control Module (ECM)
Old Jun 18, 2023 | 08:42 AM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Only the 1980 California LG4 305CI had a rudimentary ECM. The 1980 350 cubic inch 49 state did not have one. In 1981 is when all Corvettes started using the ECM
Old Jun 18, 2023 | 11:51 AM
Z51JEFF's Avatar
Z51JEFF
I believe that ground strap was permanently attached to the plastic distributor cover as mentioned,is the cover with the car? The vacuum hose shouldn't be too difficult to find where it goes,that might be why the car won't idle.
Old Jun 18, 2023 | 04:12 PM
stox258's Avatar
stox258
7th Gear
No the distributor is as shown in the picture. The earth strap is connected to the same bolt as the two resistors/capacitors. I'm not really sure what the vacuum tube is supposed to be connected to or what purpose it serves.
Old Jun 19, 2023 | 09:09 AM
stingr69's Avatar
stingr69
The copper ground strap was originally attached under the valve cover screw at one end and the black plastic distributor cover at the other end. It was held on by a wingnut. The cover is used to prevent electrical interference with the radio AM reception.
Maybe you don't really need it?
To 1980 California
