bouncing guages
Old Jul 15, 2023 | 08:08 AM
signify's Avatar
signify
Default bouncing guages
Just noticed after a few runs oil preassure guage standard to the car bounces at no throttle. A crazy bounce. you let off on gas bouncing stops? Why?
Old Jul 15, 2023 | 12:11 PM
mbitzer1's Avatar
mbitzer1
2nd Gear
Sounds like the oil pressure sender/switch. My '82 was doing the same thing (bounced around up to 80 at idle but normal when driving) and replacing the oil pressure switch fixed the problem. Bought a new one for around ~$50 on Amazon (Standard Motor Products PS-256 Oil Pressure Gauge Switch). On the '82 I found that it was pretty much impossible to get the old one off without a special wrench specified in the factory service manual (Kent-Moore J-28687 Oil Pressure Switch Wrench that I found used on Ebay for ~$10 with shipping).
Old Jul 15, 2023 | 06:08 PM
signify's Avatar
signify
Thanks were is the sending unit located on a 77
Old Jul 16, 2023 | 04:10 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Left hand side of the block, right above the oil filter.
Old Jul 17, 2023 | 08:20 AM
signify's Avatar
signify
Could that be pluged with sediment? Looks like om my 77 l-82 the block will drain if removed! There is a short nipple coming out of the block to the preassure switch
To bouncing guages
