Will my engine start without any short circuit?
Old Jul 16, 2023 | 02:26 PM
Novusuhu's Avatar
Novusuhu
Default Will my engine start without any short circuit?
Hi everyone
I removed the rest of the airco asm. on my 77 (see picture): evaporator, expansion valve, housing, lines & hoses…
I also removed the blower for the heater for now (which I will reassemble and use later).
I rolled up the wires and used some insulation tape and zip ties to hol dit together.
I put the relay back tot he firewall and reconnected the two wire sockets.
But now I have a problem… I have to put my car in another garage around the corner because of a ‘logistic emergency’. So I have to start the engine and drive it tot he other garage.
Can I start my engine without any severe problems or short circuit…
( The car started without any problems before removing the airco.)
Old Jul 18, 2023 | 05:34 PM
stevedinino's Avatar
stevedinino
I don’t see why not. As long as none of the connectors you unplugged are zipped up and not touching ground, you should be fine. Worst that can happen is a blown heater fuse.
Old Jul 19, 2023 | 07:05 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
The blue tape, the white zip ties.???
hopefully this is a very temporary thing.
And although I don't understand why anyone would delete the air-con in such a hot car. As long as that blue tape has isolated any hot wires you should be just fine.
To Will my engine start without any short circuit?
