My corvette has seen better days before. I am looking to replace my Holley 4160 carburetor. The intake manifold is an Edelbrock C3B. Any recommendations if I should replace my current carburetor with the same model or convert it to another? If so, any recommendations on where to buy one? Are all sites/spots created equal when purchasing carbs? Thanks so much!
0-90670 Holley will bolt right in its place and it tuned almost perfect for mild street engine......275-375 horsepower......been using it now for over 15 years on customer cars and I have never found anything better......
...you just have to replace or cut the "looped" bowl vent tube that runs across the top of the carb from the primary to the secondary bowls. Most air cleaners won't clear it, so you just need to cut the tube at an angle to recreate the appearance of the "standard" Holley bowl vent tubes.
But Jebby is right - that carb runs really well right out of the box on a stock or mildly modified small block. Excellent unit.
Lars
